Webcast-Catalyst9k
ACL for FTP
We add the ACL on the route for ftp service but we can login, we cannot "ls" or "dir". is it something missing? please advice
access-list 150 permit tcp any eq ftp host 202.x.x.x
access-list 150 permit tcp any eq ftp-data host 202.x.x.x
access-list 150 permit tcp any 202.x.x.x range ftp-data ftp
Silver
Re: ACL for FTP
(depending on the software used)FTP also establishes connection on dynamically negotiated ports (over 1023).
access-list 150 permit tcp any gt 1023 host 202.x.x.x
access-list 150 permit tcp any 202.x.x.x gt 1023
also, your ACL is two-way. ACLs are always applied in one direction. But i guess you can apply in both direction the same ACL.
This opens up a lot of ports though.
Re: ACL for FTP
any solution that we do not need to open all tcp great than 1024? or any work around? thanks
Best regards
Silver
Re: ACL for FTP
If you would access FTP server from Outside. Please configure as Below:
I am not able to see ant NAT statement.
interface Ethernet0
ip address 10.1.1.2 255.255.255.0
ip nat inside
interface Serial0
ip address 192.168.10.1 255.255.255.252
ip nat outside
ip nat service list 10 ftp tcp port 2021
ip nat inside source static 10.1.1.1 20.20.20.1
!--- Static NAT translation for inside local address 10.1.1.1
!--- to inside global address 20.20.20.1.
access-list 10 permit 10.1.1.1
Trouble shooting commands:
sh logs
Show ip nat translations
If you would know more about NAT: http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e76.shtml
Dharmesh Purohit
203
