Webcast-Catalyst9k
ACL in a subinterface port-channel
Hi.
I have tried to configure an ACL in a subinterface of a port-channel. But this option does not appear. The option is available for the interface port-channel or the subinterfaces of physical interfaces (gigabit,...).
The router is a 12000 with PRP and IOS ver 12.0(27)S3. The portchannel has 2 members of the same linecard (4GE-SFP-LC).
Any suggestion?
Thanks and regards.
Jose
1 ACCEPTED SOLUTION
Bronze
Re: ACL in a subinterface port-channel
It looks like Acl are not supported in a port-channel subinterface in the version this router is running.
Try this link:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/products_feature_guide09186a0080103708.html#wp1127666
Bronze
Try this link:
Hi Beth.
You have reason, it's not supported.
In your link shows:
Feature Parity on VLAN and Stacked VLAN Subinterfaces
Starting in Cisco IOS Release 12.0(32)S, VLAN and Stacked VLAN subinterfaces on Gigabit Ethernet (ISE or E4+) member interfaces in a Gigabit EtherChannel support all software features supported on a port-channel interface, including:
?Access control lists (ACLs)
?BGP policy-map accounting (only on ingress port-channel and subinterfaces)
?Hot Standby Router Protocol (HSRP) and Virtual Router Redundancy Protocol (VRRP)
?MPLS VPN Interautonomous Systems
?Multiprotocol Label Switching (MPLS) Virtual Private Network (VPN)
Jose
383
