ACLs for NAT
Kris McCormick
I have a  Cisco 2901 and need to expose an internal resource to the outside. I've set up the following:
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 1.1.1.1 4000 2.2.2.2 4000 extendable
ip nat inside source static tcp 1,1,1,1 44000 2.2.2.2 44000 extendable
ip nat inside source static tcp 1.1.1.1 443 2.2.2.2 443
ip nat inside source static tcp 1.1.1.1 80 2.2.2.2 80
ip nat inside source static 1.1.1.1 2.2.2.2
ip route 0.0.0.0 0.0.0.0 2.2.2.1
1.1.1.1 is the internal resoure IP
2.2.2.2 is the WAN IP assigned to the resource via NAT
2.2.2.1 is the gateway as defined by the ISP
Browsing and whatnot works fine so I know my basic NAT is correct but I suspect I need some ACLs to allow access from the outsdie becasue it isn't working now. Can someone point me in the right direction regarding the ACLs?
2 Accepted Solutions
Looks like you have a zone-based firewall configured (
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00808bc994.shtml).
You should see the following command somewhere:
zone-pair security xxxxx source out-zone destination in-zone (guessing on this name)
service-policy type inspect zzzzzz
then find the policy map entitled zzzzzz
policy-map type inspect zzzzzzz
class yyyyyy
Here you may have a class defined that is permitting some traffic in, look for the ACL referenced by that class. If you only have a class-default that is set to drop, you need to create a class map. Example below:
ip access-list extended NAT
permit tcp any 2.2.2.2 4000
permit tcp any 2.2.2.2 44000
permit tcp any 2.2.2.2 443
permit tcp any 2.2.2.2 80
!you also have a blanket NAT entry in there, if you intend to open all ports you need the following
permit ip any 2.2.2.2
class-map type inspect NAT
match access-group name NAT
policy-map type inspect zzzzzzzz
class type inspect NAT
  pass
if the WAN IP 2.2.2.2 is reachable from ISP out to G0/0 then you must have :
zone-pair security out-in source out destination in
service-policy type inspect out-in
policy-map out-in type inspect
class type inspect out-in
inspect
class-map type inspect out-in
match access-group name out-in
ip access-list extended out-in
permit tcp any host 1.1.1.1 eq http
permit tcp any host 1.1.1.1 eq 443
permit tcp any host 1.1.1.1 eq 4000
permit tcp any host 1.1.1.1 eq 44000
Regards.
Alain
8 Replies 8
Benjamin Kools
Kris -
Can you add the config of your Gig0/0 interface and any ACLs applied to it?
Yes sir. Here is Gig0/0
description TelePacific Internet$FW_OUTSIDE$
ip address x.x.x.26 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly in
zone-member security out-zone
load-interval 30
duplex auto
speed auto
no cdp enable
no mop enabled
service-policy output WAN-EDGE
It looks like there are no ACLs applied to it but I don't have remote access to the router right now (only a copy of the config in notepad) so I can't say for certain.
class yyyyyy
  pass
Thanks Benjamin. Here is what I found. The following config is already in the router, Ihave not made any changes yet.
zone security dmvpn-zone
zone security in-zone
zone security out-zone
zone-pair security sdm-zp-in-gre1 source in-zone destination dmvpn-zone
service-policy type inspect sdm-permit-ip
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security sdm-zp-gre-in1 source dmvpn-zone destination in-zone
zone-pair security ccp-zp-out-gre source out-zone destination dmvpn-zone
service-policy type inspect sdm-permit-gre
zone-pair security ccp-zp-gre-out source dmvpn-zone destination out-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
the policy map for sdm-permit-ip looks like this:
policy-map type inspect sdm-permit-ip
class type inspect SDM_IP
  pass
class class-default
  drop log
the access list for SDM_IP looks like this
ip access-list extended SDM_IP
remark CCP_ACL Category=0
permit ip any any
the permit ip any any makes me think it should work without modification but it's not working. I don't have experience with zone-based firewalls so I could be way off.
inspect
Regards.
Alain
Thanks Alain,
To confirm, the creation of zone-pair security out-in source out destination in would not conflict with any of the existing config, correct?
Correct, the default policy is to drop traffic tho it is not listed. If you want the extra comfort you can modify the config with the following:
   inspect
class class-default
   drop
Thanks to both of you for the help. I had to make a few changes for it to work. Here is what did it:
permit tcp any host x.x.x.x eq 80
permit tcp any host x.x.x.x eq 443
permit tcp any host x.x.x.x eq 4000
permit tcp any host x.x.x.x eq 44000
class-map type inspect match-any out-in
policy-map type inspect out-in
inspect
zone-pair security out-in source out-zone destination in-zone
