Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Adding a new ISP and trying to send some remote site traffic to it instead of the default GW
Hi,  We currently have an ISP that we point all of our default traffic too but recently added a new ISP that we will be migrating over to.  Is there a way to do a source static on the edge router or ASA that will send default route traffic to the new ISP for certain sites without breaking the old default route?
Thank you in advance
Hall of Fame Super Blue
Re: Adding a new ISP and trying to send some remote site traffic
It's not clear exactly what traffic you want to send to the new ASA because your diagram says you want to send default-route traffc or web traffic so why not just change the default route ?
However if you want to use the old default route for some traffic and the new ASA for other traffic you can use PBR on the 3rd party managed router. PBR can use an extended access-list so you can specify the traffic based on source/destination IP and source/destination port number.
If you could be more specific about exactly what you sent where we could provide an example of PBR.
Jon
Hi and thank you for your reply.  I'm afraid if I move the default route to the new ASA/ISP it will break my inbound web server traffic coming from the internet?  We have public to private nats on the old that will move over but I was hoping to do this one at a time instead of the all at once type of move.
Policy Based Routing is what I've been looking at but wanted to make sure there wasn't a simpler way since I need to contact Qwest and have them set it up.
-B
-B
Bob
Okay, that makes sense. No PBR is probably the easiest although with an MPLS network there is always the possibility of using separate vrf's each with their own default route but this may be more complicated to configure and as it is only temporary simplest way is probably the best.
Jon
184
