09-27-2010 04:05 AM - edited 03-04-2019 09:54 AM
We have a PIX 515e. This has 2 built in ethernet interfaces. My requirement is to add an additional interface card to this device so that I can add a DMZ to my network.
Below is the sh version output of my PIX:
sh ver
Cisco PIX Security Appliance Software Version 8.0(3)
Device Manager Version 6.0(2)
Compiled on Tue 06-Nov-07 19:50 by builders
System image file is "flash:/pix803.bin"
Config file at boot was "startup-config"
Encryption hardware device : VAC+ (Crypto5823 revision 0x1)
0: Ext: Ethernet0 : address is 0013.7fdd.2671, irq 10
1: Ext: Ethernet1 : address is 0013.7fdd.2672, irq 11
Licensed features for this platform:
Maximum Physical Interfaces : 6
Maximum VLANs : 25
Inside Hosts : Unlimited
Failover : Active/Standby
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : Unlimited
This platform has a Failover Only-Active/Standby (FO) license.
It shows "Maximum Physical Interfaces : 6". So, I guess I could extend the number of interfaces. Can some one please confirm this?
Also, it will be a great help if you could specify the part number of the interface card I should purchase (single port or multi port).
I am not sure, this is the correct forum to ask this question. Sorry for that..
Thanks in advance for any help,
Ribin
Solved! Go to Solution.
09-27-2010 04:13 AM
Hi Ribin,
In theory you can, however, PIX firewall is now EOL, hence the interface card is not available anymore. Part# PIX-4FE-66 is the official PIX interface part#.
Here is the EOL notification for your reference:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/prod_eol_notice0900aecd8073fa36.html
09-27-2010 04:13 AM
Hi Ribin,
09-27-2010 05:27 AM
Thank you.
- Ribin
