04-16-2006 01:27 AM - edited 03-03-2019 12:25 PM
Well KInda confused about the use of Address family?
what benefits we can have by using address-family for bgp?
04-16-2006 01:46 AM
You need different address-families to enable BGP to carry information for different types of protocols. For example, if you need to use BGP for IPv6, then you would use the IPv6 address-family. There are other uses for the address-family as well:
- IPv4 multicast routes
- IPv6 unicast/multicast routes
- vpnv4 routes - used for layer 3 VPNs.
Pls do remember to rate posts.
Paresh
04-16-2006 01:51 AM
Hello Kajif,
the main reason the address family was added to BGP was in order to support newer technologies such as MPLS or IPv6.
Have a look at this explanation on CCO:
Cisco BGP Address Family Model
HTH,
GNT
04-16-2006 07:57 PM
Benefits
Improved SNMP Query Capabilities
The search criteria for SNMP queries for routes that are advertised by individual peers are improved because the peer address is indexed before the prefix. A network operator will no longer need to search through potentially thousands of routes to obtain the learned routes of a local BGP RIB table.
Improved AFI and SAFI Support
Support is added for multiprotocol BGP. AFI and SAFI are added as indexes to the table. The CISCO-BGP4-MIB can be queried for any combination of AFIs and SAFIs that are supported by the local BGP speaker.
Restrictions
BGP 4 MIB Support for per-Peer Received Routes supports only routes that are contained in IPv4 AFIs and unicast SAFIs in the local BGP RIB table. The BGP 4 MIB Support for per-Peer Received Routes enhancement is supported only by BGP Version 4.
Remember rate this post
Yogesh
