ADSL connection (DNS)
dear all,
I would like to inform me why I don't have any DNS service through my laptop. It takes IP address, but when I hit URLs, there is no response. What should I look for? Below is the configuration of the router:
Current configuration : 4943 bytes
version 12.4
no service pad
service password-encryption
hostname Cisco877w
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
crypto pki trustpoint TP-self-signed-61071307
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-61071307
revocation-check none
rsakeypair TP-self-signed-61071307
crypto pki certificate chain TP-self-signed-61071307
certificate self-signed 01
  3082023D 308201A6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  2F312D30 2B060355 04031324 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 36313037 31333037 301E170D 30323033 30313031 35303531
  5A170D32 30303130 31303030 3030305A 302F312D 302B0603 55040313 24494F53
  2D53656C 662D5369 676E6564 2D436572 74696669 63617465 2D363130 37313330
  3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281 8100EB64
  6DACF565 D04F4A31 6F2BFB0C A94377E5 6105B1FD 19765A6D EE354DD6 2CBBDD5B
  336DE8F7 170D79EC FB3A47C9 8EC8D5F4 2E9C3E64 3366232A D9FDE553 18C778B6
  8FD12A0E 8416C8CC B08FEB86 DC23B661 879D1BF5 F8AD8585 80656BA6 0EFC0FF9
  363730FD 4F19333B 5122516F 5BB27B29 613F3EB1 E2C605E5 1192D5F3 44250203
  010001A3 69306730 0F060355 1D130101 FF040530 030101FF 30140603 551D1104
  0D300B82 09436973 636F3837 3777301F 0603551D 23041830 168014F8 B69398EA
  CA969B20 CD8FF464 4015E6D0 2D1B5F30 1D060355 1D0E0416 0414F8B6 9398EACA
  969B20CD 8FF46440 15E6D02D 1B5F300D 06092A86 4886F70D 01010405 00038181
  00A29028 EB7B94E1 D7F03D11 EC042A5D 55FE8747 42BC106C 3BA10CD2 BB26DC05
  5B0E3DAB 2F838914 15EE80C7 17862B84 05002013 2BB8CA19 DF403EE1 8E2F8CDB
  7C512CCB 17592407 57651C49 4C80780D A9F5DBDA 34E3A4A9 25A39BF4 6E9F31A5
  F2E61442 ACD55A0F 1ABAEFB5 ACF60E36 B2197F85 6C747658 C910DB62 8F2CCF4C E4
        quit
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.0.1
ip dhcp pool LAN
   import all
   network 192.168.0.0 255.255.255.248
   default-router 192.168.0.1
   dns-server X.X.X.X X.X.X.X
ip cef
no ipv6 cef
archive
log config
  hidekeys
bridge irb
interface ATM0
description Broadband link
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no ip mroute-cache
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
no cdp enable
spanning-tree portfast
interface FastEthernet1
no cdp enable
interface FastEthernet2
no cdp enable
interface FastEthernet3
no cdp enable
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description Network 1
no ip address
ip nat inside
ip virtual-reassembly
no ip route-cache cef
bridge-group 1
interface Dialer1
description Outside
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname XXXXXXX
ppp chap password 7 050A040C6F021F5B4A
interface BVI1
description Bridge for VL1
ip address 192.168.0.1 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip http secure-server
ip flow-top-talkers
top 5
sort-by bytes
ip nat inside source list 1 interface Dialer1 overload
logging history debugging
logging trap debugging
logging 192.168.0.4
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 101 remark --- Deny special-use address sources
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any log
access-list 101 deny   ip 192.0.2.0 0.0.0.255 any log
access-list 101 deny   ip 224.0.0.0 31.255.255.255 any log
access-list 101 deny   ip host 255.255.255.255 any log
access-list 101 deny   ip host 0.0.0.0 any log
access-list 101 remark --- Filter RFC 1918 space
access-list 101 permit ip 192.168.0.0 0.0.255.255 any log
access-list 101 deny   ip 10.32.0.0 0.0.255.255 any log
access-list 101 deny   ip 10.0.0.0 0.255.255.255 any log
access-list 101 deny   ip 172.16.0.0 0.15.255.255 any log
access-list 101 permit udp any any eq ntp log
access-list 101 deny   tcp any any eq telnet log
access-list 101 permit ip any any log
dialer-list 1 protocol ip permit
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
Everyone's tags (4)
Hall of Fame Super Blue
Re: ADSL connection (DNS)
If you do an "ipconfig /all" on your laptop (assuming windows) what is the DNS server ?
On your router you have -
under your DHCP config.  What is this DNS server and can it resolve internet names ?
Jon
I manually configure the DNS service at my laptop to be router's (877w) DNS which is the X.X.X.X (dns-server 193.92.150.3 194.219.227.2)
My laptop and the router cannot resolve DNS names.
Where did you get these DNS server IP addresses from ?
Jon
I set them up manually at the running configuration. These DNSs are provided from my ISP.
Can you actually connect to a website by using it's IP address ?
Jon
I was told to try:
ip name-server x.x.x.x x.x.x.x (DNS server for your ISP)
I will let you know after configuring it.
1374
