ADSL connection via Metro
mailaglady2
Is it possible to configure an atm0.837 interface to communicate with an ESR via d-slam and metro ethernet, but on the ESR side I am using the GE4/0/0.103
I cannot ping the ESR, can you pick up any problems with the attached configs?
paolo bevilacqua
should be
Interface atm0.837 point-to-point
also why pppoe enable ?
I left out the point-to -point on the configs that I sent but it is configured that way, It was initially configured for pppoe then I added the address to test LFI, PBR and QoS because i could not get it right on Vlans..
does the idea that i have in mind for an esr to use the Ge interface to communicate with the ATM interface via a ME cloud through a D-slam sound feasible?
Yes, should work.
