Community Member
ADSL - interface and dialer up, no connectivity
We lost the config to and ADSL connection we have and there is no backup. I am trying to create the config from scratch and AT&T is no help. I can't ping toward the internet.
Dub-DSL-router#sh ip int brie
FastEthernet0/0 YES NVRAM up up
Serial0/0 unassigned YES NVRAM administratively down down
ATM1/0 unassigned YES manual up up
Virtual-Access1 unassigned YES unset up up
Dialer1 YES manual up up
Dub-DSL-router#sh ip rou
Gateway of last resort is to network is subnetted, 1 subnets
C is directly connected, Dialer1 is subnetted, 1 subnets
C is directly connected, FastEthernet0/0
S* is directly connected, Dialer1
Sh run:
ip name-server
ip name-server
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0/0
ip address
speed auto
interface Serial0/0
no ip address
no fair-queue
interface ATM1/0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
hold-queue 224 in
pvc 0/35
encapsulation aal5snap
pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
ip address
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap hostname <removed>
ppp chap password 0 <removed>
ppp pap sent-username <removed> password 0 <removed>
no ip forward-protocol nd
ip route Dialer1
no ip http server
no ip http secure-server
IOS Software, C1700 Software (C1700-BK9NO3R2SY7-M), Version 12.4(18)
Dub-DSL-router#sh int atm1/0
ATM1/0 is up, line protocol is up
Hardware is DSLSAR (with Alcatel ADSL Module)
MTU 4470 bytes, sub MTU 4470, BW 384 Kbit, DLY 1330 usec,
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
23 maximum active VCs, 256 VCs per VP, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input 02:49:34, output 00:00:03, output hang never
Input queue: 0/224/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: Per VC Queueing
1001 packets input, 48109 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
2361 packets output, 174490 bytes, 0 underruns
0 unknown protocol drops
Dub-DSL-router#show vpdn
%No active L2F tunnels
%No active L2TP tunnels
%No active PPTP tunnels
PPPoE Tunnel and Session Information Total tunnels 1 sessions 1
PPPoE Session Information
Uniq ID PPPoE RemMAC Port Source VA State
N/A 35419 0002.3b00.8a6b ATM1/0 Di1 Vi1 UP
000c.ce05.c1ea VC: 0/35 UP
Re: ADSL - interface and dialer up, no connectivity
As far as I have seen line ppp pap sent-username password 0
