Webcast-Catalyst9k
ADSL loadbalancing
One router with 4 ADSL WICS,
connecting to Same IP,
Can we have Loadbalancing for out going traffic using 4 ADSL Lines
1 REPLY
Purple
Re: ADSL loadbalancing
Hi Manish,
You certainly can do so. As long as you have four routes (each of them equal cost) pointing out each of these interfaces, then CEF will load-balance over these interfaces automatically.
If you are using default routes, you can use something like the following:
ip cef
ip route 0.0.0.0 0.0.0.0 atm0.32
ip route 0.0.0.0 0.0.0.0 atm1.32
ip route 0.0.0.0 0.0.0.0 atm2.32
ip route 0.0.0.0 0.0.0.0 atm3.32
Hope that helps - pls rate the post if it does.
Paresh
112
