ADSL modem <-> Cisco 877 <-> internal network problems!
Damien Silman
Hi all,
Due to some ongoing issues with dsl interface firmwares and the kit held in our ISP exchanges; we are havign to resort to substituting out the Cisco 877 ADSL atm interface and using a seperate router supplied by the ISP to make the initial connection.
I am struggling to get the 877 to do what I want it to now though; and have subsequently found it can only handle two VLANs.
So; my ISP provided router/modem connects to the net, anythign connected to it browses fine.
This is on subnet 192.168.1.0/24 and IP 192.168.1.254 is the router
I have a port on the 877 configured in this subnet, and in VLAN666 (so i can apply ip nat outisde)
This is on 192.168.1.139
Additionally I am using VLAN1 for corporate traffic on 172.30.59.0/24 subnet and if it could handle an additional VLAN I'd also be using 10.30.59.0/24 for voice, but that's a seperate issue (unless you have any helpful suggestions!)
The 877 can ping everything, unless I tell it to use source VLAN1.
Laptop connected to to VLAN1 can ping VLAN1, VLAN666 but not 192.168.1.254 or any internet based hosts.
ISP router can ping 192.168.1.139 on the 877 but no further.
This all stinks of NAT issues but I can't figure it out; config below:
ITTEST#show run
Building configuration...
Current configuration : 4282 bytes
! Last configuration change at 16:10:10 GMT Mon Nov 11 2013
! NVRAM config last updated at 16:10:14 GMT Mon Nov 11 2013
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname ITTEST
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 10240
logging console critical
enable secret
enable password
no aaa new-model
clock timezone GMT 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 2:00
dot11 syslog
no ip source-route
ip dhcp excluded-address 172.30.59.1 172.30.59.100
ip dhcp pool dhcppool
   import all
   network 172.30.59.0 255.255.255.0
   default-router 172.30.59.1
   dns-server 172.30.59.1 172.20.0.120 172.20.0.121
   domain-name gratte.com
   update arp
ip cef
ip domain name gratte.com
ip name-server 192.168.1.254
ip name-server 172.20.0.120
ip name-server 172.20.0.121
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key <presharedkey> address xxx.xxx.xxx.xxx no-xauth
crypto ipsec transform-set 3DESSHA esp-3des esp-sha-hmac
crypto ipsec profile IPSEC-VPN
set transform-set 3DESSHA
archive
log config
  hidekeys
interface Tunnel0
description --- IPSec Tunnel to KX ---
ip address 172.30.60.1 255.255.255.0
ip ospf mtu-ignore
load-interval 30
tunnel source Vlan1
tunnel destination xxx.xxx.xxx.xxx
tunnel mode ipsec ipv4
tunnel protection ipsec profile IPSEC-VPN
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
description DATA
spanning-tree portfast
interface FastEthernet1
description VOICE
switchport access vlan 100
switchport voice vlan 100
interface FastEthernet2
shutdown
interface FastEthernet3
switchport access vlan 666
no cdp enable
interface Vlan1
ip address 172.30.59.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Vlan2
no ip address
interface Vlan100
ip address 10.30.59.1 255.255.255.252
ip nat inside
interface Vlan666
ip address 192.168.1.139 255.255.255.0
ip nat outside
interface Dialer0
no ip address
ip default-gateway 192.168.1.254
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.254
ip route 10.20.0.0 255.255.0.0 Tunnel0
ip route 10.21.0.0 255.255.0.0 Tunnel0
ip route 64.156.192.220 255.255.255.255 Tunnel0
ip route 64.156.192.245 255.255.255.255 Tunnel0
ip route 74.50.50.16 255.255.255.255 Tunnel0
ip route 74.50.63.14 255.255.255.255 Tunnel0
ip route 172.16.0.0 255.240.0.0 Tunnel0
ip route 172.30.59.0 255.255.255.0 Vlan1
no ip http server
no ip http secure-server
ip dns server
ip nat source list 100 interface Vlan1 overload
access-list 100 permit ip 172.30.59.0 0.0.0.255 any
snmp-server community  RO
snmp-server community  RW
control-plane
line con 0
password
login
no modem enable
line aux 0
line vty 0 4
password
login
scheduler max-task-time 5000
ntp server 72.8.140.222
end
Ultimately I'll be using this for a VPN, but I can't even get internet traffic currently.
Any ideas?
27 Replies 27
cadet alain
this line:
should be
ip nat source list 100 interface Vlan666 overload
You should also do NAT exemption for your VPN traffic by denying it first in this ACL
Also for voice vlan you can use switchport voice vlan command.
Alain
That was my original config, but I could not figure it out and had read enough rubbish on the internet to try setting it otherwise.
Now this is interesting; I've been conducting my ping tests from the user defing the source by using the VLAN1 IP; 172.30.59.1, I've just tried it using the actual interface instead:
ITTEST#ping 8.8.8.8 source vlan 1
% Invalid source interface - IP not enabled or interface is down
VLAN1 is active and the interface assigned is up....
What could that be then?...
sh ip int br | i Vlan
Alain
Ok, it shows the protocol as being down for VLAN 1, might this be as my laptop is no longer connect to fastethernet 0 (the only interface configured for vlan 1 access)?
I'm at home now, (UK time coming up to 9pm) so i can't plug my laptop back in to see a change.
ITTEST#sh ip int br | i Vlan
Vlan1                      172.30.59.1     YES NVRAM  up                    down
Vlan2                      unassigned      YES unset  up                    down
Vlan100                    10.30.59.1      YES NVRAM  up                    down
Vlan666                    192.168.1.139   YES NVRAM  up                    up
What can i do to change the protocol state?
additionally, I'm on the firmware that enables 2 vlans not 4, the vlan 100 and vlan 2 are not required in this set up (currently) I will need to get a third vlan in their but I can load a different firmware when this is complete and working to achieve that.
870 routers, when loaded with IOS version 12.4, can only support 2 VLANs.   If you want to load between 3 to 10 VLANs, you need to downgrade to IOS version 12.3.
Make sure you've created VLAN entries in the VLAN database.
Hi Leo,
From the sh ip int br | i Vlan command that Alain suggested I can see:
Vlan2                      unassigned      YES unset  administratively down down
Vlan100                    10.30.59.1      YES NVRAM  administratively down down
I no longer require vlan2 or vlan 100 in this config, but I am currently connected remotely. If I was on site with this device I would erase the vlan.dat, reload the device, and set the vlans up from scratch.
If I did that currently though, I would lose the connection I am currently using though VLAN 666.
Any suggestions on how to achieve this nicely? Or should I just bite the bullet and wait until I'm back on site?
ITTEST(vlan)#no vlan 100
VLAN 100 does not exist
ITTEST(vlan)#no vlan 2
VLAN 2 does not exist
ITTEST(vlan)#show
  VLAN ISL Id: 1
    Media Type: Ethernet
    VLAN 802.10 Id: 100001
    State: Operational
    MTU: 1500
    Translational Bridged VLAN: 1002
    Translational Bridged VLAN: 1003
  VLAN ISL Id: 666
    VLAN 802.10 Id: 100666
    State: Operational
    MTU: 1500
  VLAN ISL Id: 1002
    Media Type: FDDI
    VLAN 802.10 Id: 101002
    State: Operational
    MTU: 1500
    Bridge Type: SRB
  VLAN ISL Id: 1003
    Media Type: Token Ring
    VLAN 802.10 Id: 101003
    State: Operational
    MTU: 1500
    Bridge Type: SRB
    Ring Number: 0
    Bridge Number: 1
    Parent VLAN: 1005
    Maximum ARE Hop Count: 7
    Maximum STE Hop Count: 7
    Backup CRF Mode: Disabled
  VLAN ISL Id: 1004
    Media Type: FDDI Net
    VLAN 802.10 Id: 101004
    State: Operational
    MTU: 1500
    Bridge Type: SRB
    Bridge Number: 1
    STP Type: IBM
  VLAN ISL Id: 1005
    Media Type: Token Ring Net
    VLAN 802.10 Id: 101005
    State: Operational
    MTU: 1500
    Bridge Type: SRB
    Bridge Number: 1
    STP Type: IBM
So all you do is:
conf t
no interface VLAN 2
no interface VLAN 100
end
if you got nothing connected to a port in vlan1 then the SVI line protocol will stay down and so you won't be able to source any IP traffic from it.
Alain
Ok, so I'm back on site with the 877; I deleted the vlan.dat (as it still wouldn't let go of VLAN 100 and VLAN 2, relaoded, recreated.
I'm still at the same point:
ITTEST#show ip int br | i Vlan
Vlan1                      172.30.59.1     YES manual up                    up
Vlan666                    192.168.1.139   YES NVRAM  up                    up (laptop now connected)
vlan 1 can ping vlan 666 but not the ISP router/modem beyond it on 192.168.1.254; config reads:
Current configuration : 4034 bytes
version 12.4
no service pad
hostname ITTEST
boot-start-marker
boot-end-marker
enable secret
enable password
no aaa new-model
dot11 syslog
no ip source-route
   import all
   update arp
ip cef
encr 3des
group 2
crypto isakmp key address xxx.xxx.xxx.xxx no-xauth
archive
log config
  hidekeys
interface Tunnel0
ip ospf mtu-ignore
load-interval 30
tunnel source Vlan1
interface ATM0
no ip address
shutdown
description DATA
description VOICE
shutdown
no cdp enable
interface Vlan1
ip address 172.30.59.1 255.255.255.252
ip nat inside
interface Vlan666
ip nat outside
interface Dialer0
no ip address
no ip http server
ip dns server
control-plane
line con 0
password
login
no modem enable
line aux 0
line vty 0 4
password
login
ntp server 172.20.0.120
ntp server 172.20.0.121
end
ITTEST#ping 192.168.1.254
Sending 5, 100-byte ICMP Echos to 192.168.1.254 (ISP router/modem), timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
ITTEST#ping 172.30.59.123
Sending 5, 100-byte ICMP Echos to 172.30.59.123 (my laptop on VLAN1), timeout is 2 seconds:
ITTEST#ping 192.168.1.254 source vlan666
Packet sent with a source address of 192.168.1.139
ITTEST#ping 192.168.1.254 source vlan1
Sending 5, 100-byte ICMP Echos to 192.168.1.254 (ISP router/modem from VLAN1), timeout is 2 seconds:
Packet sent with a source address of 172.30.59.1
Success rate is 0 percent (0/5)
try the ping from  the pc in vlan 1 and verify you have a nat translation with sh ip nat translation
if it ain't working then can you do this:
access-list 199 permit icmp any any
do debug ip nat 199
do debug ip pack 199
and post debug output while pinging from host in vlan 1
Alain
Debugging is my main weak point on Cisco routers...
It wouldn't let me set do debug ip nat 199, so i jsut did general do debug ip nat
do debug ip pack 199 went through fine
I try to ping 192.168.1.254 or anything on the net from the laptop, the router gives me no debugging information.
If I ping 172.30.59.1 or 192.168.1.139 (router VLAN1 and VLAN666 IPs) I get the below:
01:09:46: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1, len 60, input feature, Virtual Fragment Reassembly(21), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:46: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1, len 60, input feature, Virtual Fragment Reassembly After IPSec Decryption(32), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:46: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1, len 60, input feature, MCI Check(64), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:46: IP: tableid=0, s=172.30.59.123 (Vlan1), d=172.30.59.1 (Vlan1), routed via RIB
01:09:46: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1 (Vlan1), len 60, output feature, NAT Inside(7), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:46: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1 (Vlan1), len 60, rcvd 3
01:09:46: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1, len 60, stop process pak for forus packet
01:09:46: IP: s=172.30.59.1 (local), d=172.30.59.123, len 60, local feature, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:46: IP: s=172.30.59.1 (local), d=172.30.59.123 (Vlan1), len 60, sending
01:09:46: IP: s=172.30.59.1 (local), d=172.30.59.123 (Vlan1), len 60, output feature, NAT Inside(7), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:46: IP: s=172.30.59.1 (local), d=172.30.59.123 (Vlan1), len 60, sending full packet
01:09:47: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1, len 60, input feature, Virtual Fragment Reassembly(21), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:47: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1, len 60, input feature, Virtual Fragment Reassembly After IPSec Decryption(32), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:47: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1, len 60, input feature, MCI Check(64), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:47: IP: tableid=0, s=172.30.59.123 (Vlan1), d=172.30.59.1 (Vlan1), routed via RIB
01:09:47: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1 (Vlan1), len 60, output feature, NAT Inside(7), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:47: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1 (Vlan1), len 60, rcvd 3
01:09:47: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1, len 60, stop process pak for forus packet
01:09:47: IP: s=172.30.59.1 (local), d=172.30.59.123, len 60, local feature, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:47: IP: s=172.30.59.1 (local), d=172.30.59.123 (Vlan1), len 60, sending
01:09:47: IP: s=172.30.59.1 (local), d=172.30.59.123 (Vlan1), len 60, output feature, NAT Inside(7), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:47: IP: s=172.30.59.1 (local), d=172.30.59.123 (Vlan1), len 60, sending full packet
01:09:48: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1, len 60, input feature, Virtual Fragment Reassembly(21), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:48: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1, len 60, input feature, Virtual Fragment Reassembly After IPSec Decryption(32), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:48: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1, len 60, input feature, MCI Check(64), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:48: IP: tableid=0, s=172.30.59.123 (Vlan1), d=172.30.59.1 (Vlan1), routed via RIB
01:09:48: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1 (Vlan1), len 60, output feature, NAT Inside(7), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:48: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1 (Vlan1), len 60, rcvd 3
01:09:48: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1, len 60, stop process pak for forus packet
01:09:48: IP: s=172.30.59.1 (local), d=172.30.59.123, len 60, local feature, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:48: IP: s=172.30.59.1 (local), d=172.30.59.123 (Vlan1), len 60, sending
01:09:48: IP: s=172.30.59.1 (local), d=172.30.59.123 (Vlan1), len 60, output feature, NAT Inside(7), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:48: IP: s=172.30.59.1 (local), d=172.30.59.123 (Vlan1), len 60, sending full packet
01:09:49: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1, len 60, input feature, Virtual Fragment Reassembly(21), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:49: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1, len 60, input feature, Virtual Fragment Reassembly After IPSec Decryption(32), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:49: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1, len 60, input feature, MCI Check(64), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:49: IP: tableid=0, s=172.30.59.123 (Vlan1), d=172.30.59.1 (Vlan1), routed via RIB
01:09:49: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1 (Vlan1), len 60, output feature, NAT Inside(7), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:49: IP: s=172.30.59.123 (Vlan1), d=172.30.59.1 (Vlan1), len 60, rcvd 3
ITTEST(config)#d=172.30.59.1, len 60, stop process pak for forus packet
01:09:49: IP: s=172.30.59.1 (local), d=172.30.59.123, len 60, local feature, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:49: IP: s=172.30.59.1 (local), d=172.30.59.123 (Vlan1), len 60, sending
01:09:49: IP: s=172.30.59.1 (local), d=172.30.59.123 (Vlan1), len 60, output feature, NAT Inside(7), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:09:49: IP: s=172.30.59.1 (local), d=172.30.59.123 (Vlan1), len 60, sending full packet
ITTEST(config)#
ITTEST(config)#
ITTEST(config)#
ITTEST(config)#
01:10:01: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, input feature, Virtual Fragment Reassembly(21), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:01: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, input feature, Virtual Fragment Reassembly After IPSec Decryption(32), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:01: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, input feature, MCI Check(64), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:01: IP: tableid=0, s=172.30.59.123 (Vlan1), d=192.168.1.139 (Vlan666), routed via RIB
01:10:01: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139 (Vlan666), len 60, output feature, Post-routing NAT Outside(17), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:01: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, rcvd 4
01:10:01: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, stop process pak for forus packet
01:10:01: IP: s=192.168.1.139 (local), d=172.30.59.123, len 60, local feature, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:01: IP: s=192.168.1.139 (local), d=172.30.59.123 (Vlan1), len 60, sending
01:10:01: IP: s=192.168.1.139 (local), d=172.30.59.123 (Vlan1), len 60, output feature, NAT Inside(7), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:01: IP: s=192.168.1.139 (local), d=172.30.59.123 (Vlan1), len 60, sending full packet
01:10:02: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, input feature, Virtual Fragment Reassembly(21), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:02: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, input feature, Virtual Fragment Reassembly After IPSec Decryption(32), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:02: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, input feature, MCI Check(64), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:02: IP: tableid=0, s=172.30.59.123 (Vlan1), d=192.168.1.139 (Vlan666), routed via RIB
01:10:02: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139 (Vlan666), len 60, output feature, Post-routing NAT Outside(17), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:02: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, rcvd 4
01:10:02: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, stop process pak for forus packet
01:10:02: IP: s=192.168.1.139 (local), d=172.30.59.123, len 60, local feature, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:02: IP: s=192.168.1.139 (local), d=172.30.59.123 (Vlan1), len 60, sending
01:10:02: IP: s=192.168.1.139 (local), d=172.30.59.123 (Vlan1), len 60, output feature, NAT Inside(7), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:02: IP: s=192.168.1.139 (local), d=172.30.59.123 (Vlan1), len 60, sending full packet
01:10:03: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, input feature, Virtual Fragment Reassembly(21), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:03: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, input feature, Virtual Fragment Reassembly After IPSec Decryption(32), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:03: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, input feature, MCI Check(64), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:03: IP: tableid=0, s=172.30.59.123 (Vlan1), d=192.168.1.139 (Vlan666), routed via RIB
01:10:03: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139 (Vlan666), len 60, output feature, Post-routing NAT Outside(17), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:03: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, rcvd 4
01:10:03: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, stop process pak for forus packet
01:10:03: IP: s=192.168.1.139 (local), d=172.30.59.123, len 60, local feature, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:03: IP: s=192.168.1.139 (local), d=172.30.59.123 (Vlan1), len 60, sending
01:10:03: IP: s=192.168.1.139 (local), d=172.30.59.123 (Vlan1), len 60, output feature, NAT Inside(7), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:03: IP: s=192.168.1.139 (local), d=172.30.59.123 (Vlan1), len 60, sending full packet
01:10:04: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, input feature, Virtual Fragment Reassembly(21), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:04: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, input feature, Virtual Fragment Reassembly After IPSec Decryption(32), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:04: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, input feature, MCI Check(64), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:04: IP: tableid=0, s=172.30.59.123 (Vlan1), d=192.168.1.139 (Vlan666), routed via RIB
01:10:04: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139 (Vlan666), len 60, output feature, Post-routing NAT Outside(17), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:04: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, rcvd 4
01:10:04: IP: s=172.30.59.123 (Vlan1), d=192.168.1.139, len 60, stop process pak for forus packet
01:10:04: IP: s=192.168.1.139 (local), d=172.30.59.123, len 60, local feature, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:04: IP: s=192.168.1.139 (local), d=172.30.59.123 (Vlan1), len 60, sending
01:10:04: IP: s=192.168.1.139 (local), d=172.30.59.123 (Vlan1), len 60, output feature, NAT Inside(7), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
01:10:04: IP: s=192.168.1.139 (local), d=172.30.59.123 (Vlan1), len 60, sending full packet
