Community Member
ADSL / NAT (Port Forwarding)
Hi guys,
Just wondering if someone can please help me with a configuration issue on a 857w router?
I would like to only accept email traffic from two public IP addresses to the internal mail server. I have configured "ip nat inside source... " command which works fine, however is there any way to create an access list on the outside interface? Currently "any" connection is possible to the mail server. I have tried with the access-group command in Dialer0 however as soon as it is applied, I loose all outbound connections from my LAN. The ADSL connection is using Dialer0. I have pasted the relevant config below.
Thanks for any help you can provide.
Craig
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5snap
protocol ppp dialer
dialer pool-member 1
dsl operating-mode auto
< omitted config >
interface Vlan1
description LAN
ip address 192.168.x.254 255.255.255.0
ip access-group 101 in
ip nat inside
ip virtual-reassembly
interface Dialer0
description ADSL
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname ********
ppp chap password *******
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http secure-server
ip nat inside source list 101 interface Dialer0 overload
ip nat inside source static tcp 192.168.15.12 25 interface Dialer0 25
access-list 101 permit ip host 192.168.15.0 any
access-list 101 permit ip any any
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: ADSL / NAT (Port Forwarding)
the correct acl would be:
permit tcp host host eq smtp
deny ip any host eq smtp
permit ip any any
hope this helps, please rate post if it does!
can you explain again what exactly you are trying to limit and which access-list have you tried ?
Community Member
Gday,
All our email comes from two of our anti spam appliances which have public IP addresses. I would like our email to only accept smtp traffic from the two anti spam appliances.
The anti spam servers are offsite in a data centre, all our MX records point to the anti spam appliances which then forward to our public IP address.
We are trying to confgiure the 857 to only accept smtp traffic from those two appliances via their public IPs.
I have attempted to create an access list that went something like "access-list 101 permit tcp host x.x.x.x host eq smtp"
When we use the "ip access-group 101 in" on the dialer0 interface, we loose all outbound access from the LAN.
Thanks again for your help
Craig
permit ip any any
Community Member
Good morning,
Thanks for your reply. The access list you have given is basically what I originally had. However, how can I apply this to the interface?
As can be seen in my original post (with config), I have an access list for traffic from the LAN to the internet. The access list is applied using the "ip access-group 101 in" on the LAN interface.
How does the same apply to inbound traffic from the internet through dialer0 interface, as trying to apply the access-group command to the dialer0 interface causes all traffic to stop?
regards
Craig
Hall of Fame Super Bronze
Craig,
You need to create a different ACL since 101 is used for NAT and perhaps that's the reason is not working.
Follow Paolo's advise on the ACL syntax. Use ACL 102 for this task. Apply it on the dialer interface.
ip access-group 102 in
should do it.
Community Member
Good morning,
Thanks for your reply. I have actaully used a different access list / group for the dialer0 interface. However, when applied to the dialer0 interface, I loose all connectivity to the internet. Removing the "ip access-gorup in" returns my connectivity immediately.
Please see post below. Post below is using ACL 120. Internet connectivity is not available using this config.
I have configured numerous PIX, and while the commands are slightly different, the idea is still the same. However, I seem to be missing something with regards to the dialer0 config ???? :-)
interface Vlan1
description LAN
ip address 192.168.15.254 255.255.255.0
ip nat inside
interface Dialer0
description ADSL
ip access-group 120 in
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap password 0 ******
ip http server
access-list 120 permit tcp host x.x.x.x host x.x.x.x eq smtp
If you carefully see Paolo's reply, you are missing two vital entries on that ACL.
Your ACL should look like this:
access-list 120 deny tcp any any eq smtp
access-list 120 permit ip any any
The last 2 entries will deny smtp from other sources and you need to allow ip any any, else you will get an implicit deny all.
Community Member
Sorry guys, my bad. I didn't read those last two line.
Thanks very much for the help. My apologies for dragging it out :-) should have read Paolos's config more closely.
Thanks again guys,
Craig
Thanks for the nice rating and good luck!
I will use big lettering to empathize important points next time :)
178
