ADSL QoS on 7200 LNS
Are there any issues running QoS on a Cisco 7200 LNS? I have a whole bunch of ADSL connections terminating on the LNS, can QoS be applied? I heard that this can't be done without enabling multilink? I'm trying to avoid that if possible due to IOS bugs.
1 REPLY
Silver
Re: ADSL QoS on 7200 LNS
I think it is not possible to run QOS when it has bunch of ADSL connection without Multilink.
If possible enable Auto QOS or the following is the example of Manual QOS.
interface Multilink1
ip address 10.1.61.1 255.255.255.0
ip tcp header-compression iphc-format
load-interval 30
service-policy output QoS-Policy
ppp multilink
ppp multilink fragment-delay 10
ppp multilink interleave
multilink-group 1
ip rtp header-compression iphc-format
interface Serial0
bandwidth 256
no ip address
encapsulation ppp
no ip mroute-cache
load-interval 30
no fair-queue
ppp multilink
multilink-group 1
class-map VoIP-RTP
match access-group 100
class-map VoIP-Control
match access-group 101
policy-map QoS-Policy
class VoIP-RTP
priority 100
class VoIP-Control
bandwidth 8
class class-default
fair-queue
access-list 100 permit ip any any precedence 5
access-list 100 permit ip any any dscp ef
access-list 101 permit tcp any host 10.1.10.20 range 2000 2002
access-list 101 permit udp any host 10.1.10.20 2427
access-list 101 permit tcp any host 10.1.10.20 2428
access-list 101 permit tcp any host 10.1.10.20 1720
access-list 101 permit tcp any host 10.1.10.20 range 11000 11999
431
