ADSL Router - CPU Hog
What does this mean:
*Mar 6 03:55:49.643: %SYS-3-CPUHOG: Task is running for (5000)msecs, more than
(5000)msecs (4/0),process = Exec.
-Traceback= 0x80132F88 0x801332A0 0x8012B328 0x80127680 0x80164034 0x80163BE4 0x
80163CA4 0x80161D3C 0x80161664 0x80127C2C 0x80120EB8 0x801223CC 0x801225D8 0x801
22CC0 0x801687BC 0x80354CA4
*Mar 6 03:55:54.659: %SYS-3-CPUHOG: Task is running for (10000)msecs, more than
(5000)msecs (8/0),process = Exec.
-Traceback= 0x80132C74 0x80132FA8 0x801332A0 0x8012B328 0x80127680 0x80164034 0x
80163BE4 0x80163CA4 0x80161D3C 0x80161664 0x80122534 0x801225D8 0x80122CC0 0x801
687BC 0x80354CA4 0x80354D14
Is this memory? or does the router need to be swopped?
Blue
Re: ADSL Router - CPU Hog
From the Error Message Decoder:
1. %SYS-3-CPUHOG: Task ran for [dec] msec ([dec]/[dec]), process = [chars], PC = [hex].
The indicated process has run for too long a period of time without relinquishing the processor. The process is a "CPU hog."
Recommended Action: If this message appears during startup or during OIR of a card, no action is required. If this message appears when accessing a Flash memory device, consider replacing the affected Flash memory device. If this message occurs during normal router operation, it is most probably caused by a software failure. To take advantage of recent fixes, upgrade your system to the latest Cisco IOS software release in your release train.
i've been looking at the caveats for this one.... I see similar things but this has been happening since a power failure over the weekend. If i plug a cable into any of the Fe ports they don't come up either.
282
