06-07-2012 04:32 AM - edited 03-04-2019 04:35 PM
I doubted my internet ADSL is very weak. I used Cisco 877 router to gateway internet.
I faced the problem my cisco 877 can't receive signal from ISP but I replaced to use Linksys Cisco. It worked.
So I remoted to router and issued command show dsl interface atm 0 it can't generate DMT bit per bin it showed error
DMT Bits Per Bin
.Jun 7 10:34:54.487: DSL(ATM0): rcv_cmd_ext_av 0x0 incorrect
.Jun 7 10:34:54.487: DSL(ATM0): Unable to get ADSL_GET_TC_PARAMETERS_AVAILABLE_EXT response for ADSL_GET_TC_PARAMETERS_EXT.
.Jun 7 10:34:55.455: DSL(ATM0): Unexpected ext response 68 received:None
.Jun 7 10:34:55.455: DSL(ATM0): OLR/L2 stats: expect 128 bytes, got 0 bytes
Not able to get complete DMT bin information.Retry "show dsl" after few seconds.
DSL: Training log buffer capability is not enabled
I didn't know what error message is. What does it mean?
However, I showed attenuation, power output and Noise margin
Noise Margin: 14.5 dB 18.0 dB
Output Power: 19.5 dBm 11.5 dBm
Attenuation: 35.0 dB 17.0 dB
06-07-2012 11:55 PM
As far as ADSL signa is concerned, your Noise Margin and Attentuation parameter as good; which ( if not fault in IP cloud) should give you stable ADSL service.
show caller
will give you an idea about stability of your ADSL....
HTH,
Smitesh
PS: Please rate if helpful...
06-08-2012 12:26 AM
Hi Smitesh
I followed your command show caller it showed
Active Idle
Line User Service Time Time
Vi2
PS. Do I notice output power parameter?
06-08-2012 12:47 AM
Seems like your ADSL line is UP and running stable for over 1week...
Can you elaborate what type of problem your are facing...
eg, slow response, frequent disconnection ( which I doubt seeing ADSL parameters and Stability )...
Smitesh
06-08-2012 01:39 AM
I faced disconnection frequently around 2 weeks per 1 time.
1. When it occured, router 877 can't receive siganl from ISP. I try to shut off and shut on it can't receive signal. When I replaced with Linksys Cisco router, it can receive signal. And I placed router 877 again it can receive signal.
2. Sometimes when I restart router, it took a long time to receive PPP signal.
06-08-2012 02:04 AM
I guess, then issue might be with your modem ( if you are using one )...
And if you are having line coming to your ATM port with RJ11 jack, check the local wiring before calling telco...
Smitesh
