ADSL virtual access 2 is up down
show ip int brief
FastEthernet0/0 x.x.192.253 YES TFTP administratively down down
FastEthernet0/1 unassigned YES TFTP administratively down down
ATM0/0/0 unassigned YES TFTP up up
ATM0/0/0.1 unassigned YES unset administratively down down
Virtual-Access1 unassigned YES unset up up
Virtual-Access2 unassigned YES unset up down
Dialer0 x.x.48.207 YES TFTP up up
Loopback0 x.x.72.88 YES TFTP up up
WES-LOS-2811-2#
interface ATM0/0/0.1 point-to-point
no ip address
shutdown
interface ATM 0/0/0
description *** DSL
no shut
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer0
ip address x.x.x.207 255.255.255.224
crypto map SDM_CMAP_1
ip access-group INTERNET-IN in
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxx@xxxx.com
ppp chap password 0 xxxx
dialer-list 1 protocol ip permit
#show int dialer0
Dialer0 is up, line protocol is up (spoofing)
Hardware is Unknown
Internet address is x.x.x.x/27
MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec,
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 1 seconds on reset
Interface is bound to Vi2
Last input never, output never, output hang never
Last clearing of "show interface" counters 00:11:31
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 42 kilobits/sec
0 packets input, 0 bytes
0 packets output, 0 bytes
Bound to:
Virtual-Access2 is up, line protocol is down
Hardware is Virtual Access interface
MTU 1500 bytes, BW 640 Kbit, DLY 20000 usec,
Encapsulation PPP, LCP Listen
PPPoATM vaccess, cloned from Dialer0
Vaccess status 0x44
Bound to ATM0/0/0 VCD: 2, VPI: 0, VCI: 38, loopback not set
DTR is pulsed for 5 seconds on reset
Interface is bound to Di0 (Encapsulation PPP)
Last clearing of "show interface" counters 00:11:33
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
140 packets output, 1680 bytes, 0 underruns
0 carrier transitions
thanks
1 ACCEPTED SOLUTION
Bronze
Re: ADSL virtual access 2 is up down
You may try whether Authentication protocols like (CHAP or PAP) configured properly between the two virtual accesses.
1 REPLY
Bronze
2156
