ADSL2+ errors: ATM_UCC_GetChannelHandler_PQ2CE: wrong ChannelCode
Hi folks,
i've got a cisco 886 router running ios 15.2(1)T1. If I enable "debug atm error" the router shows every second the following error meesage:
ATM_UCC_GetChannelHandler_PQ2CE: wrong ChannelCode.ATM_UCC_GetChannelHandler_PQ2CE: wrong ChannelCode.ATM_UCC_GetChannelHandler_PQ2CE: wrong ChannelCode.ATM_UCC_GetChannelHandler_PQ2CE: wrong ChannelCode.ATM_UCC_GetChannelHandler_PQ2CE: wrong ChannelCode.ATM_UCC_GetChannelHandler_PQ2CE: wrong ChannelCode.ATM_UCC_GetChannelHandler_PQ2CE: wrong ChannelCode.ATM_UCC_GetChannelHandler_PQ2CE: wrong ChannelCode.
The adsl line stays connected and there is no packetloss. All interfaces will remain up.
Config:
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 1/32
  pppoe-client dial-pool-number 1
interface Dialer1
mtu 1472
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap chap callin
ppp chap hostname feste-ip/XXXXXXXXXXXXXXXXX@t-online-com.de
ppp chap password 0 XXXXXXXXXXXXXXXX
ppp ipcp dns request accept
no cdp enable
#sh dsl int atm0
ATM0
Alcatel 20190 chipset information
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.1 (G.DMT) Annex B
ITU STD NUM:     0x03                            0x1
Vendor ID:       'STMI'                          'IFTN'
Vendor Specific: 0x0000                          0x71B8
Vendor Country:  0x0F                            0xB5
Chip ID:         C196 (3) capability-enabled
DFE BOM:         DFE3.0 Annex B (2)
Capacity Used:   78%                             58%
Noise Margin:    14.0 dB                         20.0 dB
Output Power:    19.0 dBm                        12.5 dBm
Attenuation:     17.5 dB                         11.0 dB
FEC ES Errors:    0                               0
ES Errors:       2045                             3
SES Errors:       0                               0
LOSES Errors:     0                               0
UES Errors:       0                               0
Defect Status:   None                            None
Last Fail Code:  None
Watchdog Counter: 0x1A
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x00 (UR2)
Interrupts:      338042 (0 spurious)
PHY Access Err:  0
Activations:     4
LED Status:      ON
LED On Time:     100
LED Off Time:    100
Init FW:         init_AMR-4.0.015_no_bist.bin
Operation FW:    AMR-4.0.015.bin
FW Source:       embedded
FW Version:      4.0.15
                 Interleave             Fast    Interleave              Fast
Speed (kbps):          6656                0           640                 0
DS User cells:        20541                0
US User & Idle cells:                               4268456                0
Reed-Solomon EC:        142                0             0                 0
CRC Errors:               0                0             0                 0
Header Errors:            0                0             0                 0
Total BER:                130E-130               0E-0
Leakage Average BER:      130E-130               0E-0
Bitswap:               enabled            enabled
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
010: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
020: 0 7 7 8 8 8 8 8 8 8 8 8 8 8 8 8
030: 8 8 8 8 7 8 7 7 6 6 6 5 4 4 3 4
040: 4 5 7 7 8 8 9 9 A A A A A A A A
050: B B B B B B B B B B B B B B B 0
060: 0 B B B B B B B B C B B B B B C
070: B C B B 0 B B B B B B B B B B B
080: B 2 B B B B B B B B B B B B B B
090: B B B B B B B B B B B B B B B B
0A0: B B A A B B B A B A A A A A A A
0B0: A A A B B A A A A 2 4 0 4 2 A A
0C0: A A A A A A A A A A A A A A A A
0D0: A A A A A A A A A A A A A A A A
0E0: A A A A A A A 9 9 A 9 9 A 9 9 9
0F0: 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9
DSL: Training log buffer capability is not enabled
At https://supportforums.cisco.com/message/3464080 the issue was already discussed. According this thread i should upgrade my ios version but my version is even younger that the proposed.
So any ideas?
Patrick
362
