Community Member
ADSL2 Speed Issues
Hi all,
Can someone explain to me why I would only be receiving 9mbps instead of the higher rates that I should get on ADSL2+? The output is below, I can see that the noise margin is low? does this has such a detrimental affect?
Alcatel 20190 chipset information
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.5 (ADSL2+) Annex A
ITU STD NUM:     0x03                            0x2
Chip Vendor ID:  'STMI'                          'IFTN'
Chip Vendor Specific:  0x0000                    0x71C8
Chip Vendor Country:   0x0F                      0xB5
Modem Vendor ID: 'CSCO'                          '    '
Modem Vendor Specific: 0x0000                    0x0000
Modem Vendor Country:  0xB5                      0x00
Serial Number Near:    FCZ10421129
Serial Number Far:
Modem VerChip ID:        C196 (0)
DFE BOM:         DFE3.0 Annex A (1)
Capacity Used:   95%                             99%
Noise Margin:     4.5 dB                          6.0 dB
Output Power:    20.0 dBm                        13.0 dBm
Attenuation:     39.0 dB                         20.0 dB
FEC ES Errors:    0                               0
ES Errors:        0                               0
SES Errors:       0                               0
LOSES Errors:     0                               2
UES Errors:       0                              50
Defect Status:   None                            None
Ashford#show dsl interface aTM 0
ATM0
Serial Number Far:
Noise Margin:     3.5 dB                          6.0 dB
FEC ES Errors:    0                               0
ES Errors:        0                               0
SES Errors:       0                               0
LOSES Errors:     0                               2
UES Errors:       0                              50
Last Fail Code:  None
Watchdog Counter: 0xCD
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x00
Interrupts:      25062 (0 spurious)
PHY Access Err:  0
Activations:     5
LED Status:      ON
LED On Time:     100
LED Off Time:    100
Init FW:         init_AMR_4.0.018.bin
Operation FW:    AMR-E-4.0.018.bin
FW Source:       external
FW Version:      4.0.18
                 DS Channel1      DS Channel0   US Channel1       US Channel0
Speed (kbps):             0             9246             0              1143
Cells:                    0          4415437             0          48798982
Reed-Solomon EC:          0             1286             0                 0
CRC Errors:               0               30             0                32
Header Errors:            0               27             0                 7
Total BER:                0E-0           3754E-10
Leakage Average BER:      0E-0           2309E-10
Interleave Delay:         0                2             0                 9
Bitswap:               enabled            enabled
Bitswap success:          0                   0
Bitswap failure:          0                   0
Everyone's tags (1)
193
