Spotlight January 2018 Silver
Advanced Security IOS Question 12.4
Hello I would like to implement the Advanced Security IOS on my internet router Cisco 3845 to improve the security.
What are the best practices to implement that?
Can you recommend to me a document to well implement this IOS ON MY ROUTER.
tHANKS
Lp
1 REPLY
Re: Advanced Security IOS Question 12.4
Leonardo, I personally have not implemented firewalling using IOS but rather with PIXes,
I recomend this link as it provides tips on
filtering at your edge facing internet.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_white_paper09186a00801afc76.shtml
As of design guidelines I would recommend following same guidelies you would with PIX/ASA firewalling .
Jorge/
95
