Webcast-Catalyst9k
Advantages on EIGRP MD5 authentication
What is the advantages and disadvantages of configuring EIGRP MD5 authentication on the EIGRP network.
Pls suggest it to implement on my network.
regds
Nasheer
Bronze
Re: Advantages on EIGRP MD5 authentication
Eigrp only supports MD5 authentications
advantage is MD5 is more secure as it encrypted by hash algorithm.I see no disadvantage in configuring a authentication as it wont harm the operation ,but provide more sort of security.. ;)
also its a must that authentication string on both end must match,otherwise neighbor ship will be broken...
lets hear more abt it frm experts
Hi Nasheer,
MD5 cryptographic checksums are the only authentication supported in EIGRP.The clear-text authentication is supported in RIP V2 and ospf they also support MD5.However clear-text authentication should be used only when neighbouring device does not support more secure MD5.Because EIGRP will be spoken only between cisco devices,this situation will never arise.
hope this helps.
regards,
shri :)
In addition to above posts, authentication helps a device to accept routing information only from those devices which have same authentication parameters configured.
For configurations, pls refer the below link:
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00807f5a63.shtml
hope that helps.
pls rate all helpful posts.
662
