Advice on Equipment to be use to received > 150 Vlans from SP
Hi. Currently the service provider is going to deliver more than 150 VLANs to a customer using a Metro Ethernet cloud on a Gigabit Ethernet connection. I'm trying to decide which equipment to use at the central site in order to received all those VLANS (i.e. each vlan belongs to a P2P connection) and provide routing between them.
Does a Catalyst 3750-E be sufficient for that dot1q trunk or a Cisco 3800 router is better?
Please advise.
1 REPLY
Hall of Fame Super Gold
Re: Advice on Equipment to be use to received > 150 Vlans from S
These are very different devices that should be used for different purposes.
I wold say to go with the router if you need special routing, doing VPNs, firewall or any of the other things that only a router can do.
On the other had if it is just about terminating the circuit, any layer 3 switch will suffice.
96
