Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
aes-128 ssh
Does cisco equipement supports ssh using aes-128? And in wich feature set?
thanks
Re: aes-128 ssh
For which platform are you looking this feature set?
Narayan
Re: aes-128 ssh
2600, 3600, 7200, routers
4500, 3550. 3560 switches
Re: aes-128 ssh
You can use the feature navigator to check the feature set support for every IOS
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
HTH, rate if it does
Narayan
133
