Affordable device for MAC ACL
Scott P123
I currently have a Cisco 851 which I believe does not support MAC ACLs. Does anyone know another device that I can find used that will support them? I would like it to be a small form factor if possible.
Thank You
You could use the SG300-10. It's a switch with 10*1Gig interfaces which can also filter on Mac-Adresses:
http://www.cisco.com/cisco/web/solutions/small_business/products/routers_switches/300_series_switches/index.html
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
12 Replies 12
Edison Ortiz
2960X
Those do not seem to come in the smaller variations like the 800 series. They are also not affordable for a home network.
That is a great recommendation, but this is a budget project so I was hoping to find something a little older that I can pick up used on eBay. I only need 100Mbps links as well nothing in this network will exceed that. I will keep an eye out for the SG300.. Does the SF300-08 also do Mac address filtering ?
Well the SG/SF300 are already "low-end" (at least for Cisco) ... ;-)
I only can confirm it for the SG300, but the Admin Guide is also for the FE-devices and there is nothing mentioned that they don't support it. So I would assume that it will also work on these devices.
They are low end new. I am looking for low end used
I've got a 890 and MAC-based ACL is supported.
Is this low-end for you?
According to the data sheet, 880 will support "MAC filtering", which is essentially MAC-based ACL.
And according to the 860 data sheet, this model does not support MAC-based ACL.
But the 880/890 are much more expensive then the SG300-10 (or the SF300-8 which sells for under $100.- on eBay).
LOL.
But the OP was talking about the 850 router.  I'm no expert in the SG-type, but is this a router?
no, it's just a SmallBusiness Layer3-switch that could be placed in front of the 850 to do the filtering.
That'll do.
Thank you both
