AIM-ATM and a Vwic-1MFT-G703 module in Cisco 3745
AIM-ATM in combination with a VWIC-1MFT-G703in a Cisco 3745 .cards are recognized ,when connecting the E1 line of the Provider , there seems to be a missing link between the ATM module and the E1 card.line stays down.With a cisco 2600XM there's no problem.
Purple
Re: AIM-ATM and a Vwic-1MFT-G703 module in Cisco 3745
I'm afraid I don't quite understand what the issue is. Would you be able to describe this with a bit more detail..maybe some configs would help.
Paresh
cisco 3745 (R7000) processor (revision 2.0) with 247808K/14336K bytes of memory.
Processor board ID JHY0852K1AP
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
1 Channelized E1/PRI port(s)
1 ATM/Voice AIM(s)
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of non-volatile configuration memory.
31744K bytes of ATA System CompactFlash (Read/Write)
hostname 3745
boot-start-marker
boot-end-marker
logging buffered 32000 debugging
no network-clock-participate wic 0
network-clock-participate aim 0
controller E1 0/0
mode atm aim 0
interface ATM0/0
description ATM interface to COLT.
no ip address
load-interval 30
scrambling-payload
no atm ilmi-keepalive
interface ATM0/0.37 point-to-point
description ATM 2M
bandwidth 2000
ip address
pvc 0/40
vbr-nrt 1920 1920 1
oam-pvc manage
encapsulation aal5snap
cisco 2650XM (MPC860P) processor (revision 0x300) with 124928K/6144K bytes of memory.
Processor board ID JAE08115WV0 (2703640495)
M860 processor: part number 5, mask 2
Bridging software.
Basic Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
9 ISDN Basic Rate interface(s)
1 ATM AIM(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname 2650XM
controller E1 0/0
mode atm aim 0
interface ATM0/0
description ATM interface site to COLT.
no ip address
load-interval 30
scrambling-payload
description ATM 2M
bandwidth 2000
ip address 10.253.32.66 255.255.255.252
pvc 0/40
vbr-nrt 1920 1920 1
oam-pvc manage
With the 3745 , the line doesn't come up . the E1 = UP , but the ATM interface stays down.
Purple
Just another question.. what IOS version and feature set are you running on the 3745 ?
Paresh
Soft / featureset is not realy the issue , because it has been tested with the same version = IP+
IOS (tm) 3700 Software (C3745-IS-M), Version 12.3(13), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 10-Feb-05 01:10 by ssearch
Image text-base: 0x60008AF4, data-base: 0x61C20000
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
ROM: 3700 Software (C3745-IS-M), Version 12.3(13), RELEASE SOFTWARE (fc2)
System returned to ROM by reload
System image file is "flash:c3745-is-mz.123-13.bin"
IOS (tm) C2600 Software (C2600-IK8O3S-M), Version 12.3(10a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 22-Oct-04 20:43 by kellythw
Image text-base: 0x80008098, data-base: 0x81C7B130
Purple
Howdy,
According to Feature Navigator, the AIM-Voice-30 abd AIM-ATM-Voice-30 are not supported on the 12.3(13) release for the 3745. The minimum IOS required on the 3745 is 12.3(2)T.
The feature is supported on the 12.3(10a) version for the 2650XM...
Maybe you need to upgrade your IOS and try again..
Hope that helps - pls rate the post if it does.
Paresh.
232
