10-27-2008 08:32 AM - edited 03-04-2019 12:05 AM
is there a pdf or some such that compares the performance gain of using the offloading AIM's
ie. aim-vpn/hp, aim-vpn/hpII, aim-vpn/hpIIplus, aim-vpn/SSL-3
I know the HP and HPII are eol but still I'd like to know the performance differance.
Solved! Go to Solution.
10-27-2008 09:12 AM
Cisco IPSec VPN Advanced Integration Module
The VPN Advanced Integration Module (AIM) for the Cisco 1841, Cisco 2800 and 3800 Series Integrated Services Routers optimizes VPN performance for both IPSec and SSL VPN deployments. It provides up to 40 percent better performance for IPSec VPN over the built-in IPSec encryption, and up to twice the performance for SSL Web VPN encryption.
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd80169b0a.html
Hope that helps
10-27-2008 09:12 AM
Hope that helps
