Community Member
Aircraft serial connectivity using INMARSAT
Currently have a 3270 MAR router with a smart serial interface connected to a KIV 7 (military encryption device), then KLAS TA then INMARSAT SDU then goes from aircraft via Sat to land earth station to ground terminal where ISDN replaces INMARSAT equipment and 2811 with WIC 1T for ground router. Same setup otherwise. Serial protocal goes down when in flight even though the INMARSAT system maintains a connection and strong signal. Using ppp and pulse time 5. KIV 7 security device is just a pass thru and clocking comes from ISDN connection. Not sure if its vibration, network settings, cable losses, etc... when the A/C is in flight because it's works great when AC is stationary. Any suggestions on how to optimize this connection or better track down problems.
Hall of Fame Super Gold
Re: Aircraft serial connectivity using INMARSAT
Chris, this may be difficult to diagnose, anyway can you collect "debug serial" to see if there are lead changes? You can do "logging buffered debug" before T/O and the router will save everything in "show log" for you to analyze.
Community Member
Hi Chris,
A couple of things. Does the loss of connection happen during the entire flight? Or just when the aircraft is making turns? When the aircraft is staionary (I am assuming this means grounded), everything works fine in the exact same setup? When you are statoinary, are you connecting to a different LES? Is it possible for you to try selecting a different LES while you are airbourne?
Tim
242
