07-17-2014 03:30 PM - edited 03-04-2019 11:22 PM
Hey guys,
my current setup is the following.
1. A router (192.168.1.1) connects to a switch.
2. A cisco wlan 2500 controller(192.168.1.35) connects to the switch.
3. Two aironet's 2700 (192.168.1.53) and (192.168.1.54) connect to the switch.
My SSID is visible, and I have no authentication for now.
Every time any device is trying to connect on the aironet's SSID I get failed to get IP.
Could you please advise me what should I do next?
Solved! Go to Solution.
07-18-2014 08:25 AM
Try checking your router configuration, and verify if the WLC is able to reach the router.
To add, if you are using an MBSSID setup(Multiple SSIDs) make sure there is a L3 interface in the router that corresponds to that subnet.
Though, why not use the WLC as the DHCP Server
It will put less strain on the router
07-17-2014 05:01 PM
Which device on your network is the DHCP server?
John
07-17-2014 11:15 PM
1. Which device providing teh IP to wireless clients?
2. Did you enter the DHCP ip on dynamic interface on controller ?
***If you defined or providing IP via internal dhcp server(WLC) then u must enable DHCP Proxy.
07-17-2014 11:42 PM
Try this:
1. Check the controller configuration, Go to Controller->Interfaces
Check if your PRIMARY DHCP Server is pointed
-If you want your router to be the DHCP, well place the router's IP
-If you want the WLC to be the DHCP Server, well put its own IP(Mgmt) there :)
Additionally, Make sure DHCP Proxy is enabled (through this is default)
2. Lastly, check your switch, you may have DHCP snooping configured. (If ever your router is the DHCP Server)
07-17-2014 11:47 PM
Troubleshooting : The following debug command will shows controller receiving a DHCP request from a client , transmitting a DHCP request to the DHCP server, receiving a reply from the DHCP server, and sending a DHCP offer to the client.
(Cisco Controller) >debug dhcp message enable
07-18-2014 08:17 AM
Thank you for your answers.
So far:
debug dhcp - my android device is trying to connect on the network:
*DHCP Socket Task: Jul 18 15:10:28.719: f0:25:b7:9e:30:f0 DHCP option: vendor class id = dhcpcd-5.5.6 (len 12)
*DHCP Socket Task: Jul 18 15:10:28.719: f0:25:b7:9e:30:f0 DHCP option: hostname = android-6eb4f2d7b58ddf6d (len)
*DHCP Socket Task: Jul 18 15:10:28.719: f0:25:b7:9e:30:f0 DHCP option: 55 (len 10) - skipping
*DHCP Socket Task: Jul 18 15:10:28.719: f0:25:b7:9e:30:f0 DHCP options end, len 81, actual 73
*DHCP Socket Task: Jul 18 15:10:28.719: f0:25:b7:9e:30:f0 DHCP intf:management dhcp proxy mode enabled
*DHCP Socket Task: Jul 18 15:10:28.719: f0:25:b7:9e:30:f0 DHCP Forwarding DHCP packet (340 octets) 1
*DHCP Socket Task: Jul 18 15:10:33.672: 58:94:6b:92:6b:08 DHCP option len (including the magic cookie) 72
*DHCP Socket Task: Jul 18 15:10:33.672: 58:94:6b:92:6b:08 DHCP option: message type = DHCP INFORM
*DHCP Socket Task: Jul 18 15:10:33.672: 58:94:6b:92:6b:08 DHCP option: 61 (len 7) - skipping
My router ip is: 192.168.1.1
In my cico wlan controller under wlan on the general tab I have : inetrface/inter group AS management
In the conroller --> interfaces --> management I have the following:
interface address
vlan ident: 0
ip address: 192.168.1.35
netmask: 255.255.255.0
Gateway: 192.168.1.1
DHCP information
Primary DHCP Server: 192.168.1.1
DHCP proxy mode enable
So far while I'm trying to connect on the SSID i get failed to get ip.
07-18-2014 08:25 AM
07-18-2014 08:56 AM
Thank you all, and thanks Isgabrillo. How I missed that :)!
07-18-2014 08:59 AM
Glad to help :D
