Webcast-Catalyst9k
Alert for max route in the routing table.
Is it possible to send out an alert when a cetain number of routes are imported in the routing tabel via BGP?
Re: Alert for max route in the routing table.
hi,
Its possible to drop prefix update that exceeds specified threshhold on BGP , once the router drops the exceeded threshhold, a syslog message is generated on would either be sent to a syslog server or to the router buffer.
Mohamed
Do you know if there is any type of SNMP trap I can use to send the messsage?
288
