03-27-2006 07:12 PM - edited 03-03-2019 12:12 PM
7206 PA-MC-8TE1+
all port is ok but one of port's light is dark
03-27-2006 07:45 PM
Is the port actually up ? If everything is working fine, it could just mean that the LED is not functioning - that would be an annoyance but not a major issue.
Hope that helps - pls rate the post if it does.
Paresh
03-28-2006 08:29 PM
thanks!!!
port is up protocol is up , ping is ok ,ospf neighbor is ok, everything is working fine.
one of LEDS is not working only
I have two PA-MC-8TE1+ ,another is also
03-28-2006 08:33 PM
OK, that just proves that the LED for that indicator is the problem. I'm not sure if you can actually replace the LEDs on these cards - In fact, it's probably not even worthwhile to do so.
I suggest you attach a tag to the front of the card to let your techies know that there is a problem with that LED. Apart from that, I would not worry about it too much.
Paresh
