Allow Large packets (NAT)
I have the following config on a Cisco 877, and am having problems sending large packets when NAT is enabled - I have tried disabling ip virtual-reassembly, but it does not resolve the problem(And show ip virtual-reass does not report any dropped fragments.
If I remove nat, I can happily send 8000byte packets.
interface ATM0.1 point-to-point
description Internet Network
ip address 10.2.6.26 255.255.255.252 secondary
ip address 10.2.6.2 255.255.255.252
ip nat outside
ip virtual-reassembly max-fragments 64 max-reassemblies 1024 timeout 64
pvc burnley 10/211
ubr 512
tx-ring-limit 3
oam-pvc manage
encapsulation aal5snap
interface Vlan1
description FNN1610225907 LAN
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip nat inside source list 1 interface ATM0.1 overload
ip nat inside source static 192.168.0.2 10.2.6.2
access-list 1 permit 192.168.0.0 0.0.0.255
Bronze
Re: Allow Large packets (NAT)
Try this command:
"udp-ip-fragment-enabled"
Configure 'ip tcp adjust-mss 1400' under the VLAN interface to eliminate MTU problems across varying media types. This would cause the TCP client/server to shrink the MSS of the frame and therefore, the router mayn't have to fragment the packets at all. Let us know if this helps resolve the issue.
Sundar
Thanks for the suggestions guys - I convinced the client that NAT wasn't necessary, which resolved the problem.
I will test in the lab with nat enabled to see if your suggestions work - Thanks.
Bronze
John -
If you look at the documentation it says that virtual reassembly is automatically enabled when NAT is turned on.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802299fb.html#wp1052712
I think this is causing your issue because it is exceeding the maximum ammount of fragments allowed when virtual reassembly is enabled.
You are only going to be able to send around 3300 bytes. You don't have the issue when you disable NAT because it automatically disable's virtual reassembly.
Daniel
Hi Daniel,
I also tried disabling virtual-reassembly on both Interfaces...it unfortunately didn't help
Bronze
Yea I know you said that. The documentation doesn't say whether or not it allows you to disable that when using NAT.
I think the best thing would be to try a different platform that doesn't have the virtual reassembly option, or a different code.
Daniel
I have the same problem. i fixed using the command "no-payload". eg:
ip nat inside source static udp 192.168.0.1 53 200.200.200.200 53 extendable no-payload
Regards.
828
