Am on the right path to get 3550 to decide path-iBGP?
Hi, I would really appreciate your valuable input on this. Please find attached diagram showing my configuration.
a) I need to make SWITCH3550 use its internal routing processor and do intervlan routing without
relying on RouterB.
b)In case RouterB or respective link connected to RouterB fail, I need to make the SWITCH3550
detect the failure and start routing through RouterC instead.
In case RouterC or respective link connected to RouterC fail, I need to make the SWITCH3550
detect the failure and start routing through the RouterB instead.
What I have done so far (please correct me if I am wrong):
a) In order to make SWITCH3550 do the intervlan routing, I upgraded the image on the switch
and made sure it does support L2/L3. From there I need to make sure the respective VLANs
are defined. I need to do '#enable ip routing' on the switch.
My only question here is regarding the 'default-gateway' command on the switch.
Since now the switch is going to be doing the routing, am I right that I just need to eliminate the 'ip-default gateway' entry since now the SWITCH3550 (no longer RouterB) will be the gateway for this?
b) Regarding the path selection in case RouterB or RouterC paths fail, as you can see BGP is currently configured on RouterB and RouterC.
Can you give me a hint on what would be the best approach to configure the SWITCH3550 to decide which path to take in case of failure from RouterB or RouterC?
I thought something like the below. I may be totally wrong, and I appreciate if you give me a hint.
switch3550#config t
description Add access-list 1 to switch, permitting network 2.2.2.2.0
#access-list 1 permit 2.2.2.2.0 255.255.255.0
description define a route map named localpref that sets the local preference
of the route to 200 if it matches access-list 1 - and 100 if it does not
#route-map localpref 10
# match ip address 1
# set local-preference 200
# route-map localpref permit 20
# set local-preference 100
router bgp 20
neighbor <gi0/0_interface_IP_RouterB> route-map localpref in
neighbor 10.0.0.5 255.255.255.0
#exit
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: Am on the right path to get 3550 to decide path-iBGP?
I suggest you configure BGP on the 3550 switch have it peer with the 2 routers. The 2 routers should be configure to announce a conditional default route towards the 3550 switch only if the links are up.
You can also configure which default route is preferred from the routers by configuring local-preference at the 3550 switch.
3550 switch:
router bgp 65123
neighbor [router b] remote-as [as #]
neighbor [router c] remote-as [as #]
neighbor [router b] route-map local-pref
For conditional route advertisement, read here
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hirp_c/ch05/brbbasic.htm#wp1111262
I don't have a lab right now to give you step-by-step commands.
1 REPLY
3550 switch:
router bgp 65123
122
