Webcast-Catalyst9k
Any extra power supply or power redundancy on cat 2960 switches?
Hi, I need to provide a small, but reliable 1000MB switch to connect two mainframes network adapters (intracommunication).
Since power supplies are a common point of failure in switch, is there anything I could do to offer redundant power supplies on such Catalyst 2960G-8TC switch?
Cisco Catalyst 2960G-8TC Compact Switch
Introduction
Support
Download Software for this product.
7 Ethernet 10/100/1000 ports and 1 dual-purpose uplink (dual-purpose uplink port has one 10/100/1000 Ethernet port and one SFP-based Gigabit Ethernet port, 1 port active).
LAN base image installed
Compact size and no fan
Magnet included
Order cable guard and rack mount kits separately
1 REPLY
Re: Any extra power supply or power redundancy on cat 2960 switc
Hi Friend,
Cisco RPS 675 and 300 would have been a good option but Catalyst 2960-8TC and 2960G-8TC switches do not have an RPS connector.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2960/12235se/hig/higoverv.htm#wp1107356
About Cisco RPS 675
http://www.cisco.com/en/US/products/hw/switches/ps628/products_data_sheet09186a0080150e31.html
About Cisco RPS 300
http://www.cisco.com/en/US/products/hw/routers/ps2883/products_installation_guide_chapter09186a008007d582.html
On the other hand these RPS 300 are EOS and RPS 675 will be EOS by October 15, 2007.
Ankur
*Pls rate all helpfull post
435
