Any help regarding PPPoE with Cisco 1841 router
Hello everybody
could any one help me in this please.
iam having cisco 1841 router and i want to configure this router for internet connection.
below are the configuration please let me know what is wrong, thank you.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Any help regarding PPPoE with Cisco 1841 router
Hello Ala,
the router can solve
www.google.com
try
ping www.google.com
the URL http://www.google.com is for use on a browser on a PC not sure a router can solve it.
you need the presence of the command
ip domain-lookup
ip name-server 194.170.1.7
I cannot test this in production routers
Hope to help
Giuseppe
version 12.4
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname tiger
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
enable secret xxx
enable password xxx
no aaa new-model
resource policy
clock timezone PCTime 4
mmi polling-interval 60
no mmi auto-configure
mmi pvc 0/50
mmi snmp-timeout 180
ip subnet-zero
ip cef
ip tcp synwait-time 10
no ip dhcp use vrf connected
vpdn enable
vpdn ip udp ignore checksum
vpdn-group pppo
request-dialin
protocol pppoe
interface FastEthernet0/0
description ADSL LAN Interface$ES_LAN$$ETH-LAN$
ip address 10.10.10.1 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip nat inside
ip tcp adjust-mss 1452
no ip mroute-cache
duplex auto
speed auto
no cdp enable
no mop enabled
interface FastEthernet0/1
description ADSL WAN Interface$ES_WAN$
no ip address
no ip unreachables
no ip proxy-arp
no ip mroute-cache
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
ip address negotiated
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname alaeldien
ppp chap password ***********
ppp pap sent-username alaeldien password ************
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list acl1 pool pool1
logging trap debugging
access-list 1 permit 0.0.0.0 255.255.255.0
access-list 1 permit 10.10.10.0 0.0.0.255
dialer-list 1 protocol ip permit
snmp-server community public RO
Hello Ala,
int dialer 1
ip nat outside
to have NAT to work
access-list 1 :
I don't understand the first line, the second line is enough for nat
use
access-list 2 permit 10.10.10.0 0.0.0.255
no ip nat inside source list acl1 pool pool1
no ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list 2 interface Dialer1 overload
you can use debug ppp neg and debug ppp auth to see if authentication is ok
Hope to help
Giuseppe
hello
thank you for your immediate response
i have tried your suggestion
icome up accross
all interfaces are up
but when iam pinging to the internet
it shows me this msg"Unrecognized host or protocol not running"
what to do please advice
thank you
Hello Ala,
first of all I would issue:
config
ip routing
then try again
Hope to help
Giuseppe
hello
thanks again
i did what you suggest this time when iam issuing the debug ....!!commands it shows me only debugging in on with out showing any information.
suppose if i issue debug auth"debug auth is on"
and so on , so how to deal with it
with lot of thanks
Hello Ala,
thank you very much for your kind remarks.
If you are in a telnet or ssh session you need to use
Router# terminal monitor
to see debug output
Router# terminal no monitor
to remove it
use two sessions one with term mon and another without where you are ready to disable debug if necessary (if cpu goes very high use sh proc cpu | inc util to see this on the second session)
if you like you can also post the sh int dialer 1
check if the ppp state is OPEN this would mean everything is OK.
if not ok you can post the output of debug ppp neg and debug ppp auth here.
Hope to help
Giuseppe
good after
here is out put of the interface dialer1
Dialer1 is up, line protocol is up (spoofing)
Hardware is Unknown
Internet address will be negotiated using IPCP
MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec,
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 1 seconds on reset
Last input never, output never, output hang never
Last clearing of "show interface" counters 01:01:10
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 42 kilobits/sec
0 packets input, 0 bytes
0 packets output, 0 bytes
and the state is open after issuing debug command
what do you suggest
Hello Ala,
good to hear from you.
Something is not working.
post the output of debug ppp negotiation and debug ppp negotiation so that it is possible to investigate.
You say that the state is open after issuing debug commands.
PPPoE is however a dialup technology so some event has to trigger "the call".
Depending on the client telnet software you are using you have the option to save a log file.
Hope to help
Giuseppe
hello every body
iam opening this case again becasue the last attempts did not work
so here is the running config
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
ip nat inside
duplex auto
speed auto
description WAN Interface
ip address dhcp
no ip unreachables
shutdown
duplex auto
speed auto
pppoe enable
no cdp enable
interface Dialer1
ip address dhcp client-id FastEthernet0/1
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp chap hostname falcon-wimax
ppp chap password xxx
ppp pap sent-username fsecuri password xxx
ip classless
ip http server
Hello Ala,
sorry to hear you case is still open
using PPPoE or PPPoA or any other variation the ip address is not provided by DHCP but by IPCP that is part of PPP negotiation.
so config of dialer should contain
int dialer 1
! means negotiated by IPCP
so this has to be fixed.
then you need a default static route using dialer1 as output interface
After this you can troubleshoot the pppoe session by using the following
terminal monitor
debug ppp authentication
look for errors in authentication that will stop the PPP negotiation process
you have configured parameters for CHAP and PAP with different username and passwords.
try to use
ppp authentication pap chap
instead of
ppp authenticastion pap callin
collect the output of debugs and if you like post here
to get help in understanding it.
in a working link you will see
sh int dialer1
IPCP open
Hope to help
Giuseppe
thanks alot for ur help, idid what you suggest and here is out put of debugging commands................................
what must be done, please advice.
Hello Ala,
unfortunately I cannot see the file contents this docx file format is not a text file.
May you save the file as an ASCII text file and post it again ?
Thanks for your patience and kind remarks I hope we will find a solution to your issue.
Best Regards
Giuseppe
thank you again and i'm really appreciated.
please do your best to examine the output
if you could not open the file notify me immediatly.
Alaeldien
Hello Ala,
you have an authentication issue:
the other side wants to use CHAP and your side wants to use PAP.
I : input : received on your side
O : output sent from your side
see the following sequence:
*Oct 6 05:03:08.335: Vi1 LCP: I CONFREQ [REQsent] id 248 len 18
*Oct 6 05:02:00.391: Vi1 LCP: AuthProto CHAP (0x0305C223
*Oct 6 05:03:08.335: Vi1 LCP: MRU 1492 (0x010405D4)Oct 6 05:
*Oct 6 05:02:00.391: Vi1 LCP: O CONFREQ [RE
*Oct 6 05:03:08.335: Vi1 LCP: AuthProto PAP (0x0304C023)
*Oct 6 05:01
*Oct 6 05:03:08.335: Vi1 LCP: MagicNumber 0x219
*Oct 6 05:03:08.355: Vi1 LCP: MagicNumber 0x21911AC0 (0x050621911AC0)305)
*Oct 6 05:01:14.
*Oct
*Oct 6 05:03:08.355: Vi1 LCP: O CONFNAK [REQsent] id 249 len 8E3C)
*Oct 6 05:01:14.987: Vi1
*Oct 6 05:03:08.355: Vi1 LCP: MRU 1500 (0x010405DC)[ACKsent] id 8 len 9
*Oct 6 0
*Oct 6 05:03:08.375: Vi1 LCP: I CONFREJ [REQsent] id 2 len 9uthProto CHAP (0x0305C22305)
*Oct 6 05:03:08.375: Vi1 LCP: AuthProto CHAP (0x0305C22305)CONFREQ [ACKsent] id 9 len 14
*Oct 6 05:03:08.375: Vi1 LCP: O CONFREQ [REQsent] id 3 len 14AuthProto PAP (0x0304C023)
*Oct 6 05:03:08.375: Vi1 LCP: MRU 1492 (0x010405D4)15
the key point is that if authentication fails no ip address is assigned and the dialer is torned down
there is also a mismatch in MTU: pppoe uses 8 bytes so mtu -> 1492
use
int dialer1
mtu 1492
and repeat the troubleshooting procedure with
term mon
debug ppp neg
debug ppp auth
this time you should see something different.
Hope to help
Giuseppe
Hellow Sir
i did all that, but when debugging it shows me that STATE is CLOSED
could you possibly examine the config again and tell me what might be wrong.
with my best thanks.
Alaeldien
Hello Ala,
your config looks like fine.
the command
is still present in your config ?
post the output of the same debug commands and follow the same procedure.
There are chances that PPP authentication still fails
And/OR check with provider your authentication parameters
Hope to help
Giuseppe
Hello Giusepee
iwant to thank you,because you are the only one who is dealing in my case.
so could possibly please examine the debug out put and tell me what it might be wrong
*Oct 18 12:56:56.726: Vi1 PPP: Outbound cdp packet dropped
*Oct 18 12:57:56.734: Vi1 PPP: Outbound cdp packet dropped
*Oct 18 12:58:56.742: Vi1 PPP: Outbound cdp packet dropped
*Oct 18 12:59:56.750: Vi1 PPP: Outbound cdp packet dropped
*Oct 18 13:00:56.758: Vi1 PPP: Outbound cdp packet dropped
*Oct 18 13:01:56.766: Vi1 PPP: Outbound cdp packet dropped
*Oct 18 13:02:56.774: Vi1 PPP: Outbound cdp packet dropped
*Oct 18 13:03:56.782: Vi1 PPP: Outbound cdp packet dropped
*Oct 18 13:04:56.790: Vi1 PPP: Outbound cdp packet dropped
*Oct 18 13:05:56.798: Vi1 PPP: Outbound cdp packet dropped
thank you
Alaeldien
Hello Ala,
This just an accident: however when a thread has many posts this can happen.
this specific error is not a real issue it just says it is dropping CDP packets outbound.
CDP is a Cisco protocol useful in lan environment to detect the neighbor port id.
Here it is not a problem.
on intertace dialer1
int vi1
no cdp enable
there is no use for CDP on your WAN link.
Are you still in trouble ?
I've given a look to previous posts in your last config I didn't see the command to define interesting traffic
this is needed because using the dialer you are doing a logical DDR over the PPPoE otherwise the session will be closed after idle-time expiration.
I hope this is present otherwise it has to be added.
Now, if PPP authentication is OK as seen with debug ppp negotiation and debug ppp authentication the further steps are PPPoE specific:
sh pppoe session all
example:
r3725#sh pppoe session all
Total PPPoE sessions 2
session id: 82
local MAC address: 000f.349c.eae1, remote MAC address: 000f.f7eb.5bb0
virtual access interface: Vi3, outgoing interface: Fa1/0
10026 packets sent, 10038 received
426176 bytes sent, 420238 received
other useful debug for PPPoE is
debug pppoe events
And:
r3725#sh ip int dialer 1
Internet address is 101.101.101.2/32
Broadcast address is 255.255.255.255
>> Address determined by IPCP
This happens in a working PPPoE session.
link to doc
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080093fbf.shtml#ethernetlayerclient
Hope to help
Giuseppe
Hello sir
i've issue the commands
debug ppp neg
and
debug ppp auth
after enabling the terminal monitor,
but i can't see the out put.
even i issue the command
*show vpdn session
and the output showing the State is NA
could you tell the possibility of NA status.
and let me tell you every thing seem to work fine
*dialer interface getting ip address through IPCP
but when iam pinging to suppost http://www.cisco.com
the out put come showing that unrecognized host or name or protocol is not running
could you advice please by examining the attached configuration file and see what should be removed and what to add
lot of thanks
Alaeldien
the most important thing is that the ISP *
providing us with the value of * * PVC(VPI/VCI) that is 0/50, *
where it should be *
included globally or in a diler since *
the *dialer can not accept such type *
of command unless we add mmi. *
Hello Ala,
PPPoE session is fine:
Encapsulation PPP, LCP Open
Open: IPCP
PPPoE vaccess, cloned from Dialer1
this is a DNS problem you need to configure on PCs a DNS server that is in your provider network.
give a look at:
http://www.tech-faq.com/public-dns-servers.shtml
Ask your provider what DNS server to use.
For configuring the DNS server on the router
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00800c525f.shtml
3) providing us with the value of * * PVC(VPI/VCI) that is 0/50, *
This is the ATM PVC to be used if your WAN interface was directly the ADSL link: in your case this info is already configured on the ADSL modem so don't worry about this it is right that is not used in your router in this scenario.
I would remove the mmi config I don't think relates to your scenario.
Hope to help
Giuseppe
Hellow
i've configured the router with DNS of the ISP, the problem is still exist, and i can not see the out put of the debug while its on.
my scenario is like this:
the pppoe session has been established
but it seem to be problem with NAT
the LAN interface nated as inside
the WAN interface nated out side
the dialer interface also out side
so how it could be wrong. please advice.
thanks
Alaeldien
hellow sir
idid some change and here is the issue
falcon-wimax#ping 64.233.183.104
Sending 5, 100-byte ICMP Echos to 64.233.183.104, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 264/271/280 ms
falcon-wimax#ping http://www.google.com
Translating "www.google.com"...domain server (194.170.1.7)
% Unrecognized host or address, or protocol not running.
it's a DNS issue can you deal with it
thanks
Alaeldien
Hello Ala,
www.google.com
try
ping www.google.com
ip domain-lookup
Hope to help
Giuseppe
Hello Ala,
I tested in a branch router with IPSec and without NAT I have the same problems you have showed me even using www.google.com
I would suggest you to use a PC connected on the internal LAN and to try to surf with it
Hope to help
Giuseppe
hello sir
we are done. it's all about wrong parameters from ISP.so good job has been done by you thanks alot
Hello Ala,
I'm happy that now everything works well with this PPPoE session.
Best Regards
Giuseppe
p.s. : you can address me as Giuseppe that is my name it is a normal practice here in the forums.
I've realized only now that you kept to use sir: very polite of you.
Hello Ala,
about NAT I think it should be configured only on LAN interface and dialer not the WAN interface because it has no L3 config.
Hope to help
Giuseppe
hello sir
i reomoved the NAT declaration in WAN interface, but it's still, i can ping from the router to any ip address, not by host name, none of my PCs in LAN can ping either by name or host name.
please take last look into the config file.
ya one more thing i can not see the out put of debug even after enabling the terminal monitor
advice please
Alaeldien
Hellow sir
finally ican said that we almost did it
the router is working fine i can ping by both host name or ip address, but still ihave problem ???
i can not ping any ip address or host name from any pc in the LAN
and i think some how it's related to the ACL
so i used class c ip address
192.168.1.1 255.255.255.0
and i implement ACL as follows
access-list 100 permit ip 192.168.1.0 0.255.255.255 any
is it ok? if yes what might be wrong/
thank you.
Alaeldien
845
