enc
Apply policy-map to ATM VC
Hi All - please help before I am getting insane.
I have the following router
Cisco IOS Software, 3700 Software (C3745-SPSERVICESK9-M), Version 12.3(8)T10, RELEASE SOFTWARE (fc2)
ROM: System Bootstrap, Version 12.3(6r) [cmong 6r], RELEASE SOFTWARE (fc1)
System image file is "flash:c3745-spservicesk9-mz.123-8.T10.bin"
Cisco 3745 (R7000) processor (revision 2.0) with 247808K/14336K bytes of memory.
Processor board ID FCZ10037332
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
2 FastEthernet interfaces
1 ATM interface
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
with an NM-1A-E3 adapter.
I am trying to apply the following policy-map to the configuration
policy-map ph_xx_up34368k_lo10000k
class network_management
bandwidth 16
random-detect dscp-based
random-detect exponential-weighting-constant 1
random-detect dscp 16 200 300 10
random-detect dscp 48 100 200 10
class COS1
priority 1000 125000
police 1000000 conform-action set-dscp-transmit ef exceed-action drop
class COS2
bandwidth 5200
random-detect dscp 26 200 300 10
random-detect dscp 28 100 200 10
class COS3
bandwidth 2500
random-detect dscp 18 200 300 10
random-detect dscp 20 28 40 10
class COS4
bandwidth 900
random-detect dscp 0 20 40 10
interface ATM1/0
description description
mtu 1500
bandwidth 34000
no ip address
no ip proxy-arp
no ip mroute-cache
logging event subif-link-status
no atm auto-configuration
no atm ilmi-keepalive
interface ATM1/0.132 point-to-point
bandwidth 34000
pvc toper 1/132
service-policy output ph_xx_up34368k_lo10000k
but when I'll take an sh polcy-map interface, the map is not applied. Is anyone able to see the error?
  • WAN Routing and Switching
Re: Apply policy-map to ATM VC
You may have omitted ip info on the sub-if. If not, I assume that it does not work because ip processing is not enabled on the interface.
You can verify this by running a "sh ip int ATM1/0.132"
Leo
Purple
While I have not come across this exact issue myself, I would suggest that you explicitly configure some traffic-shaping parameters under the PVC e.g.
bandwidth 34000
pvc toper 1/132
vbr-nrt 34000 34000 1
Hope that helps - pls rate the post if it does.
Paresh
enc
Yes - you are right - unfortunately I have been a bit to fast with my cut and paste - here you have the correct interface configuration:
interface ATM1/0
mtu 1500
bandwidth 34000
no ip address
no ip proxy-arp
no ip mroute-cache
description
mtu 1500
bandwidth 34000
ip address x.x.x.x 255.255.255.252
no ip proxy-arp
rate-limit output access-group 182 5400000 675000 675000 conform-action set-dscp-transmit 26 exceed-action set-dscp-transmit 28
rate-limit output dscp 16 16000 4000 4000 conform-action transmit exceed-action transmit
rate-limit output dscp 48 16000 4000 4000 conform-action transmit exceed-action transmit
rate-limit output dscp 46 1000000 1250000 1250000 conform-action set-dscp-transmit 46 exceed-action drop
rate-limit output access-group 182 5000000 125000 125000 conform-action set-dscp-transmit 26 exceed-action set-dscp-transmit 28
rate-limit output access-group 183 2696000 337500 337500 conform-action set-dscp-transmit 18 exceed-action set-dscp-transmit 20
rate-limit output access-group 184 896000 112500 112500 conform-action set-dscp-transmit 0 exceed-action set-dscp-transmit 0
pvc toper 1/132
vbr-nrt 10000 10000 1
vc-hold-queue 1024
oam-pvc manage 0
oam retry 3 5 1
oam ais-rdi 10 3
encapsulation aal5snap
protocol ip inarp
and my problem is, that I am not able to apply he policy-map under "pvc toper 1/132".
I have tried to remove the rate commands - as far as I understand they are not feasible on e.g. 7300, but they should be allowed on the 3745.
enc
I found it myself - it was a bandwidth mis calculation. Easy to see - it was in clear text in the log.
340
