Community Member
Are modules for the 3640 router hot-pluggable
Can you add an NM to a 3640 while it's running without destroying things? I'd like to add a third fast ethernet port.
1 ACCEPTED SOLUTION
Re: Are modules for the 3640 router hot-pluggable
Hi Friend,
With regards to the NM module being hot swappable , the 3640 hundred series does not support hot swapaable only certain modules in the 3660 series will support that.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis2600/hw_inst/nm_inst/nm-doc/instnetm.htm#wp1038116
Ankur
*Pls rate all helpfull post
1 REPLY
Hi Friend,
Ankur
142
