10-31-2011 06:52 AM - edited 03-04-2019 02:06 PM
I'd like to know if Cisco has a similar command to "AS PATH EXPAND" in Juniper. If you see the juniper documentation:
You can expand or add one or more AS numbers to an AS sequence. The AS numbers are added before the local AS number has been added to the path.
It would be something similar to an as-prepend but insert the new AS numbers before the local as not after it as as-prepend do.
Thanks.
10-31-2011 07:06 AM
It does the same thing .
on juniper it would be like.
policy-statement as-path-expand {
term expand {
from {
route-filter < Prefix > orlonger;
then as-path-expand last-as count < number >;
Ex- Prefix 10.0.0.0/8 and count 2
Remote router will get AS path prepended by 2.
on cisco it would be like.
route-map prepend permit 10
set as-path prepend
10-31-2011 07:21 AM
No,
the as-prepend function inserts after the local AS. So the BGP neigbor see your prefixes with the AS PATH:
What as-path-expand does in a Juniper is insert the AS number before de local AS. So the neighbor sees the following AS PATH
The issue is that we want use only a BGP session to anounce prefixes for a private AS and prefixes for a public AS.
The AS origin should change depend on prefixes (using on prefix-list).
10-31-2011 07:07 AM
Hi Antonio,
If I am not mistaken you are enquiring about AS path appending not prepending in cisco world. umm. You can try using the set as-path prepend last-as. This prepends the first AS in the AS-path (neighbor’s AS). You can use this command in an inbound route-map to simplify your configuration and make the route-map independent of the neighbor’s AS number.
However, if you are actually asking about appending the AS in a outbound route-map. I am not sure if you could do that on cisco devices.
Kishore
10-31-2011 07:22 AM
Yes I need appending the AS in a outbound BGP policy.
Thanks any way.
