Community Member
as-path prepend
Hi there
When you use as-path prepend, and you are adding an as-path multiple times, why is this not concidered as a loop, after all you will have the same AS number appearing
multiple times
Cheers
Per
1 ACCEPTED SOLUTION
Re: as-path prepend
Per,
An AS-PATH loop occurs when a BGP router received an update from a remote AS with its own AS in the AS path.
Seeing a given AS more than once in an AS path is not a AS loop unless it is has been it your own.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Re: as-path prepend
Per,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Community Member
Re: as-path prepend
Got ya
Thanks a lot
284
