AS5300 Controller E1 not coming up
The IOS is Version 12.0(5)T1
Router5300#Sh contro e1 0
E1 0 is down.
Applique type is Channelized E1 - balanced
Cablelength is Unknown
Far End Block Errors Detected
Receiver has loss of signal.
Version info of Slot 0: HW: 1, Firmware: 4, PLD Rev: 11
Framer Version: 0x8
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x4B,
Board Hardware Version 2.0, Item Number 800-3881-2,
Board Revision A0, Serial Number 16383401,
PLD/ISP Version 0.1, Manufacture Date 28-Nov-1999.
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line Primary.
Data in current interval (188 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
188 Slip Secs, 188 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 188 Unavail Secs
Data in Interval 1:
900 Slip Secs, 900 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 900 Unavail Secs
What is wrong?
regds,
prasanna
Re: AS5300 Controller E1 not coming up
Hello Prasanna,
Far End Block Errors usually point to a physical problem. The 'Receiver has loss of signal' output indicates that there is a problem at the provider end. You could try and reset your modem first, or switch the E1 controller to crc-4 (or toggle between CRC4 and no-crc4). Can your provider loop back to the modem ?
GNT
Thanks for reply
The same provieder output when given to another as5300 the E1 int on that immediately come up.Framing type CRC4 or NO-CRC4 does't make any difference.
When local loopback is given the int is showing locally looped but is still showing as E1 0 is down.
regds
prasanna
VIP Purple
Hello Prasanna,
you have slip Secs and fr loss secs in your controller output, try and change or toggle the clock source in your controller configuration, to something else than clock source line primary...
GP
Thanks GP
Tried changing the clock source of E1 0 to secondary and that of E1 3(Configured as PRI) clock source as primary.After that the E1 0 is up but it is showing as cablelength is Unknown.Following is output
E1 0 is up.
No alarms detected.
The E1 3 (PRI) is now working ok though it is showing following status
E1 3 is up.
No alarms detected.
When the dial up traffic is routed to E1 0 it is not picking up any modem from the bank.
regds,
Prasanna
266
