AS5300 IOS UPGRADING PROBLEM (XMODEM)
hi
I have problem . i m uploading IOS via Ronmon but error are as follow.
Frist status is :::
System Bootstrap, Version 12.0(2)XD1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
AS5300 platform with 131072 Kbytes of main memory
loadprog: error - trouble reading file magic number
open: failed to find and/or load the bootloader: "bootflash:c5300-js-mz.123-15.b
in"
loadprog: error - on file open
boot: cannot load "cisco2-AS5300"
device does not contain a valid magic number
boot: cannot open "flash:"
boot: cannot determine first file name on device "flash:"
boot: cannot load "bootflash:"
and mem info is :::::::::
rommon 1 > meminfo
Main memory size: 128 MB. Packet memory size: 16 MB
Available main memory starts at 0xa000e000, size 0x7ff2000
Packet memory starts at 0xa8000000
NVRAM size: 0x20000
when I run commond Xmodem than errors comes
1) transfer canceled by remote system.
and 2nd ::::::::::::
modem c5300-is-mz.122-17.bin
Do not start the sending program yet...
File size Checksum File name
0 bytes (0x0) 0xffff c5300-js-mz.123-15.bin
WARNING: All existing data in bootflash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n [n]: y
Ready to receive file c5300-is-mz.122-17.bin ...
BB0
ERR:Image size exceeds free flash space
rommon 3 >
plz check the thing and advice.
I have tried all possibe solutions but result is same.
Purple
Re: AS5300 IOS UPGRADING PROBLEM (XMODEM)
It appears that the file size is larger than your flash memory.
One option is to to just download the image to DRAM so that the router at least boots up. To do that, enter in: 'xmodem -r'
This will not solve your problem in the longer term: you will need to choose a smaller image or upgrade your flash.
Hope that helps - pls rate the post if it does.
Paresh
I have tried but result is
rommon 1 > xmodem -r
xmodem: illegal option -- r
usage: xmodem [-cy]
-c CRC-16
-y ymodem-batch protocol
rommon 2 >
plz check and advice.
Silver
You can try using xmodem,
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
if there is any problem try to boot the ios externaly,
by boot xmodem: command
after that try to transfer the ios to flash using tftp or copy xmodem from the priveledge prompt,
Hope this helps you,
Purple
Does the rommon support tftpdnld ? Can you try and run it to see if it is available ?
Paresh
My friend i have treid all these solution frim the link also that you have sent me.
and also i have treid the ftftdnld procedure . but do not work.
any other solution.???
430
