AS5300 stuck in ROM mode
I am using Cisco AS5300 with IOS 'c5300-is-mz.123-6.bin'. Whenever the AS reboots (abnormally, e.g. power recycle), it stuck in ROM mode. Then there is a need to hard reset the AS, OR reset the AS through console.
Is there any other way? upgrading IOS? etc.
Thanks in advance
Re: AS5300 stuck in ROM mode
I haven't used an AS5300 in a while, but this *sounds* like a configuration register problem. Don't remember the setting but the config reg is a bitmap, the bit that says "boot to IOS" must be OFF. Someone here should know...
Paul
This is not config register issue. It's 0x2102 (boot from IOS)
Any other ideas?
Then I'd say TAC case it...
I have same experience with as53500.
Have you find any solution for this problem.
Thank in advance,
Unfortunately not :(
122
