01-25-2010 01:56 AM - edited 03-04-2019 07:17 AM
One further question
If I use the example in
i. will it revert to connection (1) the primary one automatically when it comes back up?
ii. What version of software does it need to run
01-25-2010 02:33 AM
i) Yes it will
ii) version 7.x or later so for the ASA all versions because they only started with v7.x
Jon
01-25-2010 06:43 AM
Yes, As mentioned by Jon it will revert back to the primary route as soon as its back.
with Version 7.x and later , the ASA supports object tracking feature.
unfortunately, the security appliance doesnt support loadbalancing, so its not possible to loadbalance the traffic.
Mohamed
