ASA 5505 8.3.2 port forwarding
I'm used to configure ASA with version 8.0. Since version 8.3 is installed on our ASA's port forwarding isn't function any more.
Can someone help me with the configuration. Allready tried various options, but nothing works.
Also can't see the traffic coming to the ASA.
I've copied my configuration in attachement.
Thanks in advance.
Jean-Luc
Hall of Fame Super Blue
Re: ASA 5505 8.3.2 port forwarding
Thanks in advance.
Jean-Luc
Jean-Luc
static (inside,outside) tcp 177.10.10.10  80 192.168.5.10 80
is pre 8.3 and as you know means any request received for 177.10.10.10 port 80 should be forwarded to the inside server 192.168.5.10 on port 80.
8.3 equivalent -
network object web-server
host 192.168.5.10
nat (inside,outside) static 177.10.10.10 service tcp 80 80
You may also find this doc useful which gives examples for pre 8.3 NAT and it's 8.3 equivalent -
ASA NAT
Jon
Hello Jon,
Thanks for the advice, but i've allready tried this commands.
In this exact order. Only with port 3389 (RDP)
Still this doesn't seem to work.
I've retried it with there commands:
object network ....
host
nat (inside,outside) static interface service tcp 3389 3389
and the following firewall rule:
access-list outside_access_in extended permit tcp any host eq 3389
Also applied the rule by entering:
access-group outside_access_in in interface outside
Still don't see any of the traffic coming to the ASA.
Could it be that this rule is a problem??
nat (inside,outside) source dynamic any interface
Please let me know.
Try to change the order of your nat rules. Move the rdp rule up, to first. You can do this fine with ASDM gui.
regards
Joachim P.
1250
