ASA-5505 Problem
Hi! Fighting my ASA-5505 for a while now, still I can't get the inside users connected to the internet. My ADSL is an Routed-Subnet (Static IP, 4 IPS on a single line). When I connect a single PC directly to my modem port, the following IP settings are required: IP: 87.x.x.83, SubnetM: 255.255.255.248, Gatw: 87.x.x.81, DNS: 62.58.62.132 & 62.58.94.130. Works fine. Nevertheless, I can't get my network to work when the are connected trough the ASA-5505. Here's my setup. Can anyone please help?;
: Saved
ASA Version 7.2(4)
hostname ciscoasa
domain-name default.domain.invalid
enable password encrypted
passwd encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 87.x.x.84 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 62.58.62.132 62.58.94.130
dhcpd auto_config outside
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd enable inside
dhcpd dns 62.58.62.132 62.58.94.130 interface outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:ce889e733fab16482b4dee3936a38a73
: end
Hall of Fame Super Blue
Re: ASA-5505 Problem
Try adding
route outside 0.0.0.0 0.0.0.0 87.x.x.81
Jon
Hi Jon,
Is that a NAT rule? I'm working with GUI interface instead of CLI. I have CLI setup in the meantime, but don't know any commands yet.. :( Thanks!
No it's not a NAT rule. The ASA needs to know how to send packets to the Internet. Without adding the route the ASA does not know where to send the packets.
So you need to add the route above to tell the ASA to send Internet packets to the 87.x.x.81 address.
Jon
Hi Jon, thanks for your quick response...As mentioned, I'm using the GUI version. Can you please explain where this line should be added? Thanks again!
(Maybe it's an idea to start a online chat of remote control session?)
Sorry, i'm not that familiar with ASDM but i have found this doc which shows how to add a static route with ASDM -
http://www.cisco.com/en/US/docs/security/asa/asa72/asdm52/user/guide/routing.html#wp1102477
Jon
Oke Jon, is it possible to post some instruction on how to set this up trough CLI. It looks like I can connect using the CLI, consule. Do I have to set it in config mode first? Please help! :(
IT WORKS!!!! Thanks JON!
I entered CLI mode and added the rule mentioned earlier and...SUCCESS!!
Glad you got it working :-)
Jon
133
