Webcast-Catalyst9k
hcr
asa 5510 Active/Standby failover
Hi I have 2 asa 5510 which should be running active/standby failover.
When i turn on the standby unit, the primary says "replicating with mate" and then "replicated with mate" then the standby unit reboots, starts replicating again and again and again
show ver :
dneasa1# sh ver
Cisco Adaptive Security Appliance Software Version 7.0(4)
Device Manager Version 5.0(4)
Compiled on Thu 13-Oct-05 21:43 by builders
System image file is "disk0:/asa704-k8.bin"
Config file at boot was "startup-config"
dneasa1 up 8 days 0 hours
Hardware: ASA5510, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 64MB
BIOS Flash AT49LW080: @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CNlite-MC-Boot-Cisco-1.2
SSL/IKE microcode: CNlite-MC-IPSEC-Admin-3.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: Ethernet0/0 : address is 0013.c480.e164, irq 9
1: Ext: Ethernet0/1 : address is 0013.c480.e165, irq 9
2: Ext: Ethernet0/2 : address is 0013.c480.e166, irq 9
3: Ext: Ethernet0/3 : address is 0013.c480.e167, irq 9
4: Ext: Management0/0 : address is 0013.c480.e168, irq 11
5: Int: Not licensed : irq 11
6: Int: Not licensed : irq 5
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 10
Inside Hosts : Unlimited
Failover : Active/Standby
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 0
GTP/GPRS : Disabled
VPN Peers : 150
This platform has an ASA 5510 Security Plus license.
Serial Number: JMX0951K077
Running Activation Key: 0x3535e664 0xa4153590 0x84d3a894 0xbf503070 0x8238cb9c
Configuration register is 0x1
Configuration last modified by enable_15 at 09:36:08.917 UTC Thu Feb 16 2006
dneasa1#
failover commands
failover
failover lan unit primary
failover lan interface failover Ethernet0/2
failover key *****
failover replication http
failover link state Ethernet0/1
failover interface ip failover 192.168.254.1 255.255.255.0 standby 192.168.254.2
failover interface ip state 192.168.253.1 255.255.255.0 standby 192.168.253.2
Can anyone give me a hint on how to solve
/Henrik
1 REPLY
Silver
Re: asa 5510 Active/Standby failover
Upgrade to ASA 7.0.4.4 code solved a similar problem. check out the following link for configuring failover :
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a008045247e.html
131
