Webcast-Catalyst9k
ASA 5550 configuration
hi, i have about 10 vlans on my network,i want all my vlans on inside network.what is the best way to configure ASA?
1 REPLY
Re: ASA 5550 configuration
Create the 10 vlans as 101,102,103.... created on the switch and then connect the trunk port to the ASA physical interface e0/0
On the ASA create subinterfaces like below
hostname(config)# interface ethernet0/1.1
hostname(config-subif)# vlan 101
hostname(config-subif)# nameif inside101
hostname(config-subif)# security-level 100
hostname(config-subif)# ip address 10.0.0.1 255.255.255.0
hostname(config)# interface ethernet0/1.2
hostname(config-subif)# vlan 102
hostname(config-subif)# nameif inside102
hostname(config-subif)# ip address 20.0.0.1 255.255.255.0
and then for allowing communication between the subnets of these vlans use the command
hostname(config)# same-security-traffic permit inter-interface
154
