07-21-2014 12:04 PM - edited 03-04-2019 11:23 PM
How do I configure a wireshark capture on the ASA?
03-05-2015 08:05 AM
Wireshark?!?
Isn't enough the logging on the ASA?
Or in case, you can send the logs to an external syslog for further analyzing on it (also wireshar). But this is depending of which tools on syslog you're using.
regards
03-05-2015 09:38 AM
What is the issue and what are you trying to check?
03-09-2015 11:56 PM
You can use this link to set up captures then, export them and analyze them on Wireshark:
https://supportforums.cisco.com/document/69281/asa-using-packet-capture-troubleshoot-asa-firewall-configuration-and-scenarios
Please don't forget to rate and mark as correct the helpful Post!
David Castro,
03-12-2015 12:21 PM
Use the Packet Capture wizard. After you stop your capture, there is a button to "Save Captures" that will bring up another box asking for the save type as "Text" or "PCAP". Save it as a PCAP then open it with Wireshark.
If this is not what you are wanting, let us know.
Also, See this link, it may help.
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/118097-configure-asa-00.html
Brian W
03-12-2015 12:28 PM
Create your capture
enter the following command...
https://X.X.X.X/capture/testcap/pcap
Where X is the IP Address of the inside interface
