ASA Hairpinning
I would like to configure ASA 5510 to allow VPN clients access to the network behind the firewall, IPsec vpn tunnels, and internet access.
Is that hairpinning? How do I configure to allow internet access?
It is already setup to allow access to the network, just not the internet.
Thanks.
Re: ASA Hairpinning
Eric, from what I have read hairpining would be if you were using what is refer as public internet on a stick to allow vpn clients to asa outside internet without using split tunneling in asa. You could either use with split tunneling or outside nat enabling hairpining with same-security-traffic permit intra-interface
Configuring split tunneling
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080702999.shtml
Or public internet on a stick.
same-security-traffic permit intra-interface allows the traffic to exit out on the interface it was received on
global (outside) 1 interface
nat (outside) 1
rate any helpful post if it helps
Jorge
Re: ASA Hairpinning
Your configuration issue is split tunnel, than say Jorge.
Hairpining is other concept.
617
