ASA simple routing problem
janos.csaszar
I'm sure, the problem is not a big one, however I'm stuck for now.
I managed to configure an ASA 5505 under home circumstances, with ADSL internet connection. All went smooth, I could rease the internet, and could reach the device from the internet.
The device is deployed now in a server park, with internet connection through a fixed IP and the first hop is a switch of the ISP.
The other side is a small LAN.
I can remotely manage the device, even port forwarding works to LAN, however there is no LAN communication with the WAN. I cannot ping and/or reach anything outside.
I added one static route on the outside, pointing to my ISP switch.
On the LAN I gave the inside leg of the ASA as the default gateway.
Could someone give me some clue where to proceed?
Thank you in advance!
16 Replies 16
Good to hear that you are up and running. Which NAT command did you use?
hi sure,
Iam hari, can u send to me the show tech report of asa 5505, or please add icmp echo-reply commands. then u reach from outside.
regards
hari.
