ASBR - how to redistribute an E2 route?
How can I redistribute an E2 route from OSPF to BGP?
Here is the config so far:
address-family ipv4 vrf arena_201
redistribute connected
redistribute static
redistribute ospf 900
no auto-summary
no synchronization
exit-address-family
Here are the routing tables:
D_H11_ZGR10_02#sh ip route vrf gw_inet_900
Gateway of last resort is 172.28.133.240 to network 0.0.0.0
[taken out some routes]
B 172.30.1.0
[20/1] via 10.200.200.240 (alte_welt_999), 00:18:08, Vlan999
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
B 10.200.200.0/24 is directly connected, 00:18:24, Vlan999
B 10.10.90.0/24
[20/1] via 10.200.200.240 (alte_welt_999), 00:18:24, Vlan999
O 10.190.1.0/30 [110/2] via 172.28.133.240, 00:19:15, Vlan900
O*E2 0.0.0.0/0 [110/1] via 172.28.133.240, 00:19:15, Vlan900
D_H11_ZGR10_02#
D_H11_ZGR10_02#sh ip route vrf arena_201
Gateway of last resort is not set
172.17.0.0/24 is subnetted, 3 subnets
B 172.17.9.0
[20/1] via 10.200.200.240 (alte_welt_999), 00:19:25, Vlan999
B 172.17.8.0
B 172.17.6.0
172.16.0.0/24 is subnetted, 1 subnets
B 172.16.1.0 is directly connected, 00:19:09, Vlan100
172.28.0.0/16 is variably subnetted, 13 subnets, 3 masks
B 172.28.160.0/24
[20/10] via 10.200.200.240 (alte_welt_999), 00:19:25, Vlan999
C 172.28.161.0/24 is directly connected, Vlan201
B 172.28.162.0/24 is directly connected, 00:19:26, Vlan202
B 172.28.131.18/32
[20/1] via 10.200.200.240 (alte_welt_999), 00:19:26, Vlan999
B 172.28.150.0/24
B 172.28.128.0/24
B 172.28.129.0/24
B 172.28.130.0/24
B 172.28.133.0/24 is directly connected, 00:19:26, Vlan900
B 172.28.135.0/24
B 172.28.140.0/24
B 172.28.143.0/24
B 172.28.0.0/17
[20/10] via 10.200.200.240 (alte_welt_999), 00:19:26, Vlan999
172.30.0.0/24 is subnetted, 1 subnets
B 172.30.1.0
[20/1] via 10.200.200.240 (alte_welt_999), 00:19:10, Vlan999
B 10.200.200.0/24 is directly connected, 00:19:27, Vlan999
B 10.10.90.0/24
[20/1] via 10.200.200.240 (alte_welt_999), 00:19:27, Vlan999
B 10.190.1.0/30
[20/2] via 172.28.133.240 (gw_inet_900), 00:19:27, Vlan900
D_H11_ZGR10_02#
As you can see, the route to 0.0.0.0 is not redistributed, because it?s an E2 route. How can I achieve, that this route is redistributed?
Best regards,
Martin Funke.
Re: ASBR - how to redistribute an E2 route?
I'm not sure whether it is your case but I read in one of Cisco's documents the following:
"Default redistribution of IGPs or EGP into BGP is not allowed unless default-information originate is specified."
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_command_reference_chapter09186a00800ca5ac.html#wp1019783
//Mikhail Galiulin
Hello Martin,
try the command:
redistribute ospf 900 match external 2
and see if your default route gets redistributed.
You also might want to check this link:
Understanding Redistribution of OSPF Routes into BGP
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800943c5.shtml
GNT
I tried that. But against all expectations it doesn't work. Perhaps it's necessary to reset all routing processes after that?
Best regards,
Martin Funke
Germany.
sounds helpful, but doesn?t work.
Nevertheless, thanks for your help.
Best regards,
Martin Funke
Germany.
Silver
Configure default-information originate under the BGP address-family. This command is necessary for BGP to advertise the redistributed default route.
Check
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a00801a807f.html#wp1118958
207
