Community Member
ASR 1001 OTV Port-Channel
I saw in the release notes that 3.10 for the ASR 1001 supports port-channel for the internal otv interface.  I upgraded to that release and it lets me use a port-channel interface, but it won't let me use the serivce instance command on the L2 interface.  I can add the channel-group command but not any otv commands.  Has anyone seen this yet?
Tom
1 REPLY
Hi tom,Not sure if you have
Hi tom,
Not sure if you have resolved this issue, but, I hope you are configuring the port-channel with all the service-instance configurations. If yes, and you are getting into issues, please do post the output of the issue, we can have a look at the same.
225
